Author Topic: Stanley No. 3 Project  (Read 2797 times)
« on: April 24, 2018, 01:04:25 PM »
Hello, I found this at a good price at the flea. My plan is to clean it up, using some traditional methods, and some parts will go into the tumbler. I will post pics when re-assembled. Regards, Lou
« Last Edit: April 25, 2018, 12:04:52 PM by lptools »
Re: Stanley No. 3 Project
« Reply #1 on: April 24, 2018, 01:13:22 PM »
If I recall correctley the low front knob was used up until about 1918 or 1919. What does the TM on the cutter look like,You can narrow down the date it was made by the trademark and Patent numbers if it has any.
« Reply #2 on: April 24, 2018, 03:10:29 PM »
Hello, There are patent numbers on the bed, can't see enough of the label , though.  I will try to put a date on it when I am done. Thanks, Lou
Offline aaronhill
« Reply #3 on: April 24, 2018, 03:52:33 PM »
that's gonna clean up nice!
« Reply #4 on: April 24, 2018, 05:53:40 PM »
No. 3 is a nice size; some folks prefer them as their primary smoothing plane.
« Reply #5 on: April 24, 2018, 09:18:05 PM »
Hi Lou,
Based on the 3 patent dates on the bed, the low front knob, and the small adjusting nut, it is probably a type 11 made from 1910-1918. Should have a "V" logo iron...once you get that little bit of rust taken care of.
I’m looking forward to seeing how it turns out.
I too like the no. 3 size, they just feel right.
Good luck,
« Reply #6 on: April 25, 2018, 12:17:04 PM »
Hello, Guys. Thanks for the replies and the info. It is a V-logo iron. This is the finished product. The only pieces that did not go in the tumbler were the knob, tote, and casting. The right side was worse than I thought, and the bottom needs a little more work. All of the cleaning on the casting was done by hand, 100 grit, 150 grit, and 220 grit emery cloth on a granite surface plate. That's it for now, the iron will get sharpened at a later date.Regards, Lou
« Last Edit: April 25, 2018, 12:44:46 PM by lptools »
« Reply #7 on: April 25, 2018, 12:49:57 PM »
Sweet!
« Reply #8 on: April 25, 2018, 05:18:33 PM »
Nice job Lou!! It looks great.
« Reply #9 on: April 25, 2018, 05:38:32 PM »
Hello, Guys. Thanks!!!! Well worth the effort to bring this tool back to life!! Regards, Lou
