Author Topic: Saber saw ? Mystery tool  (Read 6485 times)
Offline JoeCB
« on: March 10, 2017, 05:15:25 PM »
I have this mystery tool,  Manning-Bowman, model 73532 2000- 2400 strokes per min. by Mc graw Edison Co. Boonville, MO . I sure looks like a version of a saber saw but the end of the ram is nothing that will accept a blade that I Know. The ram has no opening slot or hole. Cross drilled and tapped and has two locating pins, one on each side. If the threaded hole is intended for a clamp it would only work with ins of the pined sides of the ram.
Any ideas?
Joe B
Re: Saber saw ? Mystery tool
« Reply #1 on: March 10, 2017, 08:28:01 PM »
Looks like it takes a Sawzall type blade, and the clamping piece may be missing
« Reply #2 on: March 10, 2017, 09:45:15 PM »
Why is the trigger in the wrong spot and what is that handle underneath the body of that thing for. Are you sure that is a saw.
Offline JoeCB
« Reply #3 on: March 11, 2017, 07:14:31 AM »
Well it's some kind of reciprocal stroke tool, either a saw, filer or nibbler. The business end of the ram is not of a configuration that would accept a conventional saber saw blade, that's what has me puzzled. An old tool catalog would tell the tail.
Joe B
« Reply #4 on: March 11, 2017, 11:17:31 AM »
Multiple companies made reciprocating saws - think Sawzall - in this configuration.  I owned a Sears version for a while, but the ergonomics didn't work as well as the D-handle-kind-of-drill shape of the Sawzall and its competitors.  If you're not familiar with the sawzall:
I abandoned it as soon as I got a Makita (and later, a Milwaukee) sawzall-style reciprocating saw; not sure which thrift store was blessed with it.
I agree that the clamp is probably missing.  It's possible, of course, that McGraw-Edison used proprietary blades of a peculiar size, as Wen did with the Allsaw.  If you've got a friend with a reciprocating saw, borrow a blade and hold it against the end of the shaft.  If it fits, it might not be hard to fabricate a clamp; only you can say whether it would be worthwhile.
The two pins and two threaded holes look to be for mounting the blade vertically to the saw (when it's upright) or horizontally.  It might be awkward holding that saw sideways (particularly in comparison to the sawzall), and changing the blade would let you hold it upright regardless.  That said, when used for its highest woodworking purpose, demolition, a sawzall gets twisted around to all kinds of angles as the cutting proceeds, and having to stop and switch blade mounting would really slow down the party.
« Reply #5 on: March 11, 2017, 12:51:00 PM »
Hello, Joe. Bill got me thinking, and you should check out the WEN Zipp Saw , Ebay item number   282390769876. Regards, Lou
« Reply #6 on: March 11, 2017, 01:29:24 PM »
Yep.  That's Wen's sawzall version of the Allsaw, which is configured more like a saber saw.  Wen used blades that were midway in size between the then-standard 1/4" saber saw shank and the then-and-now standard 1/2" reciprocating saw blade.  The Allsaw is a lovely tool
but the difficulty in sourcing blades (one source that I know of) and limited range of sizes makes it a toy, not a tool, in my opinion.
Offline JoeCB
« Reply #7 on: March 13, 2017, 08:03:26 AM »
Well guys thanks for the suggestions. I do have both a saber saw and a Sawzall and neither style blade seems to be compatable with this strange gizzmo. I'll keep searching. Maybe someone will come up with a catalog cut at some point.
Joe B
Offline Catch22!
« Reply #8 on: March 31, 2017, 10:31:20 PM »
It is a saw.  Here is a picture of one with the blade.
Offline JoeCB
« Reply #9 on: May 30, 2017, 10:28:44 PM »
Yep' that's the one Thanks "catch22" ... and sorry for the late thank you, I haven't checked this thread in a while
Joe B
« Reply #10 on: May 30, 2017, 11:08:02 PM »
HeHe I've got it now how you use it. For some reason I was thinking it was held the opposite way.
