Author Topic: Unknown Tool  (Read 2200 times)
Unknown Tool
« on: January 07, 2017, 07:49:43 PM »
Hello, I have been cleaning up the basement , and I came across this tool. It is unmarked, edges are sharp, overall length is 10-1/2", and there is 7" of steel showing, and the widest part is approx. 1". The handle looks homemade, the blade guard looks like a flat washer. I have no idea what the tang looks like, it is snug to the handle. Regards, Lou
Re: Unknown Tool
« Reply #1 on: January 07, 2017, 08:09:13 PM »
Is the shape solid, like a file, or hollow on the side you didn't show us?
Re: Unknown Tool
« Reply #2 on: January 07, 2017, 08:16:33 PM »
Hello, Bill. I am showing both sides, but it is not clear, darn thing keeps rolling around!!!!!!!!. It is concave/convex in shape. I will add a better photo. thanks, Lou
Offline Catch22!
Re: Unknown Tool
« Reply #3 on: January 07, 2017, 10:25:54 PM »
Oh do I remember those.  Worked as a youth planting pine trees in the national forest.  This is a type of Widger or Dippler.  A device for planting seedlings.  They now come more as cone shaped
Here is a modern one.  https://www.amazon.com/Secret-Garden-Burgon-Stainless-Transplanter/dp/B0079ZFSZQ/ref=sr_1_27?s=lawn-garden&ie=UTF8&qid=undefined&sr=1-27&keywords=transplanter
Here is a picture on how it is used for small seedlings.
« Last Edit: January 07, 2017, 10:29:04 PM by Catch22! »
Re: Unknown Tool
« Reply #4 on: January 08, 2017, 04:34:23 AM »
Hello, Catch22. I had a post a while back, and the tool was identified as a dibble. The business end of a dibble is thick &  flat. The tool I am showing would not last very long in soil. Regards, Lou
Offline Catch22!
Re: Unknown Tool
« Reply #5 on: January 11, 2017, 11:38:52 PM »
Joe, did you look at the widger in the link?
Other potential would be a seed/grain sack sampler.  What are the dimensions of the tool   How wide and long?
Offline Batz
Re: Unknown Tool
« Reply #6 on: January 13, 2017, 04:09:09 PM »
I think it's a splicing tool, for splicing ropes.
Here a slightly more recent one.
« Last Edit: January 13, 2017, 06:17:11 PM by Batz »
Re: Unknown Tool
« Reply #7 on: January 13, 2017, 06:42:16 PM »
Hello, I will someday remove the handle, this will give all of us better insight to the original make, and use, of this tool. Thanks for all of the responses, Lou
Re: Unknown Tool
« Reply #8 on: January 14, 2017, 11:27:10 AM »
Hello, Did you ever have the need for a thin edge, small pickle fork? I was able to gradually pry this apart with a horseshoe calk wrench. The tool has a tang for a brace, the handle was force fit by the previous owner. Still no factory stampings, but I am still cleaning. This has a notched tang, similar to the notch on a Buck Bros. 83 and 84 countersink. The Buck Bros reamers were half round, but solid. So my next guess is that this is either a Tapered Spoon Bit, or a Tapered Spoon Reamer, for a brace.Regards, Lou
Re: Unknown Tool
« Reply #9 on: January 14, 2017, 02:14:26 PM »
Ah ha!     Could it be a brace gouge bit that was reground for hand reamer use.
Re: Unknown Tool
« Reply #10 on: January 14, 2017, 03:31:32 PM »
Hello, Bill. The machining appears to be very true, doubtful this was re-ground. Regards, Lou
