Author Topic: Complete Shop sale Nazel 3B  (Read 4081 times)
Offline lkg276
« on: October 22, 2016, 12:40:24 PM »
METAL WORKING SHOP SALE
Tycee Grice is selling the contents of Jerry's home workshop.  Jerry and Tycee had an architectural metal business for over 34 years, and Jerry was also a talented blacksmith and knife maker.  All equipment, tools, stock, fixtures, cabinets, etc. are for sale.
Tycee is open to lot purchase on any or all items. Please call if interested in major equipment or lot purchase.
If you wish to examine major equipment, contact John Butler at 850-445-1476 or Bill Adams at 850-528-2822 to make arrangements.
The equipment list is a partial list as there is too much to inventory. Please go through the pictures for more details. Photos are grouped to make downloads easy. See links for download at end of list.
SALE WILL BE HELD SATURDAY NOVEMBER 19, 2016
TERMS ARE CASH ON DAY OF SALE
MAJOR EQUIPMENT
•   Nazel 3B power hammer, runs good, ($9,000.00 minimum bid)
•   Reiter (Kuhn) 75# power hammer, runs good, ($6,000.00 minimum bid)
•   Rotary Phase converter to run both power hammers on single phase power ($1,000.00 minimum bid)
•   Bader– BIII 2x72 belt grinder, 1.5 HP variable, 8” Wheel, vertical platen, 2 fork tips, work platens, runs well (
•   Mill Drill- MSC model 9512518, magnetic chuck, angle vise, clamp set, collets, runs and table moves but needs clean up
•   Surface grinder, converted to 2x72 belt, magnetic chuck, runs and table moves but needs clean up
•   Complete Speedy melt casting setup, furnace, blower, flasks, sand, crucibles, handling tools, safety gear, temp probe,
•   Preheat cabinet 3’x3’x3’ (uses Speedy Melt blower?)
•   Welders- 2 Miller Regency 250 MIG with spool gun and gas bottle, 1 Lincoln SP170 MIG w/gas bottle on cart
•   Hydraulic Press
•   Cold saws- 1 Okay, 1 Omes
•   Forge- very large coal with chimney and power blower
•   Forge- Coal, 2 medium
•   Forges- propane, 2 large, 1 smaller
•   US Cavalry portable forge, excellent condition
•   Anvils- 1 large, 1 medium, 1 small
•   Post Vise- 1 large, 1 medium
•   Brazing torch and 3 bottles
•   Smith Lifetime miniature torch
•   Cutting torches- 2 with bottles
•   Air Compressor, stationary, running
MINOR EQUIPMENT (Partial List)
Tongs-
Buffers- (2), homemade
1 x 42 Belt Grinder,    1/3 HP + 40 belts
Planishing Hammer- air-powered, “Body Iron” by Allen Engineering Products Inc.
Engraver- Scott Model SM-300, sign engraver, motor spins by hand but hums only on
starting. 5 sets fonts, plastic sign stock
Plastic Sign Edger- Scott Model SM-08
Sears belt/disc sander, 2/3 HP 6” belts, on stand
Flat Platen Circular Grinder   ½ HP on stand
Mini Lathe- jewelers type, needs clean up
Mini Sander-   needs cleanup
Grizzly Flex Arm hand grinder
Angle Vise
Drill press, small craftsman, bench model, runs, needs cleanup
Drill press, small chines, runs, needs clean up
Drill Press, Craftsman Floor type, needs clean up
Miniature Repoussé Tools in Prince Albert can
Large Repoussé tool set in wooden block
Central Pneumatics Sand Blast Cabinet    model 3844 NIB
2/3 of a Roll of Inswool (2in)
Wrought Iron chain, large pile
Air compressor
Heavy casting ladle, 2-man with hook, pick, for pouring melt from overhead crane
Knife making screws
Wax pot
Small cutoff saw, homemade
Dremel Moto-tool
Sharpening stones – Large
Variac, 15 amp 120V
Titanium sheets (3)
Brass sheets
Hammers, punches, flatters, all sizes, types and shapes 75+
10 Drawer heavy duty storage unit (2)
Hand Shear for strip steel
Damascus strip steel in coils
Jigs for fence panels and scrolls
Scroll benders, 1 hand, 1 power
Heat Treat Oven, electric
Sand Blast cabinets, 1 Empire, 1 Central Pneumatics (NIB),
Hand tools, all types
Welding clamps
Stock, aluminum and steel (hundreds of pounds)
Architectural elements for fences and panels (hundreds of pounds)
Screws, fasteners, welding rods,
Aluminum Ingots 1.5’x1.5’x’3’ stack
Jib Crane (homemade)
LINKS TO DOWNLOAD PICTURES
Click on blue links to download zip file of pictures.
If you have trouble downloading large files, download the “Smaller Pictures”. This file contains all photos in the other files plus numerous others.
Smaller Format Pictures (Contains all pictures below plus others) 1 @ 13 GIG, 1 @ 38 GIG)- https://www.dropbox.com/sh/g6681bw9f0qtf05/AADQlbZIW4gA5I4C0oIre_kIa?dl=0
THESE FILES ARE MUCH LARGER (13 to 78 GIG) BUT BETTER RESOLUTION
Anvils- https://www.dropbox.com/sh/jahm6pvdf5c1ikf/AACWmxPvweCYVEWeR1qwJDdba?dl=0
Architectural Elements- https://www.dropbox.com/sh/s7wxtx70s4w6u69/AAAAPXlM3GVHWtmx9mek0pt_a?dl=0
Forges- https://www.dropbox.com/sh/gl31va55b94pbns/AACO-aO3XTsFTwV-bjA2SiILa?dl=0
Jigs and Fixtures- https://www.dropbox.com/sh/9qm499t6uqz9r6b/AADaL7SAkadDG9GFs196ACjwa?dl=0
Knife Making- https://www.dropbox.com/sh/y12pv20nw604q0g/AADC-EiOgtLqjvrRBYJQlmbQa?dl=0
Major Equipment- https://www.dropbox.com/sh/b2n0dmgc32ujcre/AADZ_8DwMWgasy3f7xQZo8eKa?dl=0
Small Equipment and tools- https://www.dropbox.com/sh/6mnn5y2izaljyov/AACGV-XyO6mMRnKO8IIBvHeCa?dl=0
Speedy Melt Casting Operation- https://www.dropbox.com/sh/m18z42d489rdgno/AADG86quT_Qq8XA-oimPkfj_a?dl=0
Stock- https://www.dropbox.com/sh/qb793uxv5jkjl2h/AAB5OEw9mRlX7lehnQptcT30a?dl=0
Unique tools and Items- https://www.dropbox.com/sh/7442u5xg0t8uo8x/AAChYjVWVzOSz3fVPI8XpbLta?dl=0
Welders and torches- https://www.dropbox.com/sh/005o44gzzrppi3h/AAA8F50nGmAhn9_8ElOdtJQva?dl=0
