Author Topic: Homestead valve wrenches maybe?  (Read 2708 times)
Offline skylab
« on: October 12, 2011, 07:28:15 PM »
any ideas?
Homestead Valve Co?
I may look for other sizes.
Looking to buy farm implement wrenches.  They can be orphans
Re: Homestead valve wrenches maybe?
« Reply #1 on: October 12, 2011, 07:30:38 PM »
Probably right- for gas valves or welding bottles.
« Reply #2 on: October 12, 2011, 07:41:06 PM »
Homestead Valve co of Pittsburg,PA is mentioned in Steam engineering around the 1920's
There are also references in 1902 of them building a brass foundry, and of them making 2-way and 3 way valves, and they are mentioned in Railway Gazette...for 'blowoff valves' (pressure relief valves for boilers) so I suspect they were primarily making steam valves.
« Reply #3 on: October 13, 2011, 12:01:20 AM »
Depending on the opening size, they could well be for acetylene or mapp gas cyinders, some manufacturers provided a round handle on the valve stem but some of the companies just left the square valve stem sticking straight up and you had to use a wrench similar to what you are showing here to open the valve. The stems were usually 1/4'' or 5/16'. The wrenches tended to get lost quite often and the general practise was to use an cresent style  wrench and the pointed end of a spud wrench thru the hole in the end of the cresent to get enough leverage to open and close the valve
