Author Topic: Reviving an old Socket Box?  (Read 2084 times)
Offline Twertsy
« on: February 02, 2016, 01:21:21 PM »
Folks,
Any tips on bringing the text back alive on this old Quickway socket box?  It appears to just be grease and dirt.  The text appears to be engraved into the wood slightly.  Anyone got a good way of cleaning old wood?
Re: Reviving an old Socket Box?
« Reply #1 on: February 02, 2016, 01:27:14 PM »
Any of the common cleaners: Murphy's oil soap, Simple Green.
If it's grease, mineral spirits on a rag should do quite a bit to clean it up; although real turpentine cuts through grease like anything (but it's spendy).
Offline Twertsy
« Reply #2 on: February 02, 2016, 01:48:04 PM »
Use a rag, soft toothbrush, or.............?
« Reply #3 on: February 02, 2016, 01:56:22 PM »
I agree with Bill on the products he listed. I will  usually use mineral spirits first  Keep rag damp and turn often when dirty get a new rag. Usually this is enough but if not murphys next and simple green if necessary, just be careful of the lettering. Oh tooth brush is ok too.
Offline leg17
« Reply #4 on: February 02, 2016, 04:28:02 PM »
I suggest a couple of careful trial spots.
Using Murphy's, I have cleaned the printing right off with the grease and dirt.
The box looked great but the graphics were a lot weaker.
« Reply #5 on: February 02, 2016, 07:07:20 PM »
For the 9,753,271st time; there are cleaners and there are SOLVENTS.
Solvents do NOT clean.
Solvents, particularly on wood generally cause the DIRT to migrate deeper into the wood.
If it's dirty, wash it with a cleaner.  Murphys and Simple Green along with Fast Orange are CLEANERS.
Mineral Spirits is a SOLVENT.  It is also a penetrant.  Mineral spirits will carry dirt into wood just like it carries lanolin into steel.
« Reply #6 on: February 02, 2016, 08:39:24 PM »
OK, my 2 cents worth,   yes, Murphy's would be my 1st try,  and I would only start on the inside sidewalls for a test.
work any of the listed cleaners, bur I will state again, try it on the walls of the box 1st, not the bottom with the lettering.
good luck.
« Reply #7 on: February 02, 2016, 08:44:04 PM »
Just not your personal one, though! lol
« Reply #8 on: February 02, 2016, 08:47:42 PM »
 :grin:
Offline Twertsy
« Reply #9 on: February 03, 2016, 05:45:50 AM »
Folks,
I appreciate the tips and am going to attempt to clean a small portion this afternoon with Murphy's.  I'll post the results.
