“You can use an eraser on the drafting table or a sledgehammer on the construction site.” - Frank Lloyd Wright
That's a lot of tool just to remove a battery cable. Looks like it would do the job even if you didn't loosen the bolt!
The battery in my old MGA was under the miniscule rear floorboard.
Quote from: Papaw on November 17, 2015, 09:49:32 PMThe battery in my old MGA was under the miniscule rear floorboard.A model had a pair of 6 volt batterys, 1 behind each seat bulkhead with the driveshaft between them.That red piece of sheet metal wasn't a floorboard, it was the battery cover, and the compartment above was storage for the convertible top.
