Author Topic: black oxide?  (Read 9681 times)
Offline fflintstone
  • Former master curmudgeon
black oxide?
« on: May 10, 2011, 06:06:48 PM »
Has anyone on this board done a real hot process black oxide treatment?
I am not interested in a cold process like the caswell plating stuff.
Any practical advice for the hot process?
Re: black oxide?
« Reply #1 on: May 10, 2011, 08:53:59 PM »
The process isn't a whole lot different from bluing or parkerizing, but the chemistry is damn nasty.
I have 2 recipes but I won't run either because of the chemistry involved and byproducts.
Offline fflintstone
Re: black oxide?
« Reply #2 on: May 11, 2011, 01:20:43 PM »
I know it is pretty nasty, the one recipe I have has a lot of lye in it. I have some stuff that I need to refinish and I like a black oxide finish.
Re: black oxide?
« Reply #3 on: May 11, 2011, 04:38:59 PM »
Why don't you like the cold processes? The copper oxide process works well if the metal is clean, and provides a nice black finish, it was often used for pliers etc...
The Hydroxide process you seem to know about, it is nasty, clouds of hydroxide vapor are not pleasant, nor are they healthy. Be aware that sodium hydroxide vapor can cause instant, permanant blindness if you get it in your eyes!)  It's main benefit was that it was cheap, not that the finish was particularly good, parkerizing is a much better process.
fwiw, some of the chemicals in the typical recipies for that process aren't really necessary, they are in there for production cleaning the metal, deoxidizing it etc, if you start with carefully cleaned metal, you don't need them (typically chlorides)
There is a black lead process, it is also nasty, and very toxic. (I think this was more common on sheet than tools tho)
You can also use oil quenching to produce a semi dark finish, but you need to heat the metal quite hot, the smiths sometimes do this...
Offline fflintstone
Re: black oxide?
« Reply #4 on: May 18, 2011, 06:33:11 PM »
Now that we are up and running again, anybody have a real life experience?
Offline Dustin21
  • Defiance Ohio
Re: black oxide?
« Reply #5 on: May 18, 2011, 06:44:06 PM »
i used gun bluing on a ratchet before and some plier...  turned out well.
i love sk tools/boxes and indestro super/select tools if you have any for sale or want to part with let me know.  also need a  7/8 williams superench
Re: black oxide?
« Reply #6 on: May 18, 2011, 07:51:07 PM »
I have used gun bluing on steel wrenches with some success. It did not work well on cast wrenches.
Offline Dustin21
  • Defiance Ohio
Re: black oxide?
« Reply #7 on: May 18, 2011, 07:57:23 PM »
heres some pics..   i wire wheeled the entire thing before appling and made sure all the chrome and rust was gone
Offline fflintstone
Re: black oxide?
« Reply #8 on: May 18, 2011, 09:56:07 PM »
looks cool dustin, thats what I want to do.
Re: black oxide?
« Reply #9 on: May 19, 2011, 08:23:43 AM »
I've found that Formula 44/40 cold blue gives the quickest and darkest results.
Offline fflintstone
Re: black oxide?
« Reply #10 on: May 20, 2011, 08:49:09 AM »
Typically any cold process is far less durable. I am not looking for quick, I am looking for durable.
Re: black oxide?
« Reply #11 on: May 21, 2011, 11:39:40 AM »
I can't remember exactly who, but somebody over at the "other" forum redid some impact sockets with an aftermarket kit, and they came out nice. Posted before and after pics - couldn't tell they weren't factory finish. FYI
