Author Topic: What is this called and who made it.  (Read 2160 times)
Offline lebaron
« on: October 15, 2014, 08:44:54 PM »
Marked Forged Steel and Pat Pending on handles. Thanks.
Re: What is this called and who made it.
« Reply #1 on: October 15, 2014, 08:52:14 PM »
it looks like it would open the links on a tire chain.
many companies that made chains also sold the tool, some were made by other
companies for them.
Weed tire chain was one that comes to mind
« Reply #2 on: October 16, 2014, 06:29:07 AM »
Weed is what they look like to me also, but I've never seen them with the bent tips.  First time for everything.
« Reply #3 on: October 16, 2014, 09:59:37 AM »
with the bent ends, it is easier to use.
make believe that you are looking at a set of tire chains on the floor and the open end
of the links are facing up.  it would be easier to use a bent tool than to try to do it in
a flat position.
many moons ago, we used a chisel before the boss bought the proper tool. it was not fun.
Offline mvwcnews
« Reply #4 on: October 16, 2014, 11:45:52 PM »
The bend is an "aftermarket" modification by a skilled blacksmith.
Offline bear_man
« Reply #5 on: October 17, 2014, 12:06:26 AM »
Talk about serendipity!  I just this morning pulled a Weed set of these out of a gallon of vinegar, then brass-brushed the gunk off of it.  Besides "WEED," mine says "PAT'D July 29, 1913."  The head is cupped a tiny bit but not bent to 90° like yours, and mine have deeper and wider "reliefs" than yours do on the inside of the jaws in pic #2.  I'd not've guessed they were tire chain pliers.  Seems early, to me, but I'll track down the patent (and probably learn something, as usual).
