Author Topic: What are these  (Read 3129 times)
Offline chips
What are these
« on: September 15, 2014, 09:50:43 PM »
I found these in the bottom of a box I purchased.  Everything in it was automotive related.  The left is marked Appleton and the right is marked Ford.  Thanks in advance for any help.
Re: What are these
« Reply #1 on: September 15, 2014, 11:27:41 PM »
thing on the left looks like a electrical connector, weatherhead I believe the name is.  not sure what the right one is? got a few fords around here but that don't look familiar?
Offline chips
Re: What are these
« Reply #2 on: September 16, 2014, 12:26:20 AM »
Here's the Ford marking.  If it helps any, I have one that doesn't have any markings except "Pat'd Oct. 31 1916"
Re: What are these
« Reply #3 on: September 16, 2014, 08:29:52 AM »
Appleton was famous for their spot lights , high quality. Possibly a piece from an early light.
The Ford piece looks like some sort of trigger , with the follower, or a closing device.
You could try the Ford Barn forum if you don't get an answer here.
http://www.appletonlighting.com/
« Last Edit: September 16, 2014, 10:33:11 AM by Lostmind »
Offline JoeCB
Re: What are these
« Reply #4 on: September 16, 2014, 09:05:04 AM »
I'm guessing that the Ford thing is an ignition timer part. The roller would run on a cam and the arm trips an electrical contact.... Just a guess
Joe B
Re: What are these
« Reply #5 on: September 16, 2014, 10:29:03 AM »
Joe B
Joe jarred my memory . Here' one on ebay
http://www.ebay.com/itm/Early-FORD-MODEL-T-IGNITION-TIMER-ROLLER-Ford-Script-Made-in-Canada-/271426508081?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3f3247d531
Re: What are these
« Reply #6 on: September 16, 2014, 11:22:47 AM »
Ahhh should have known that! my T's have Atwater Kent distributors, I collect old radios so it is just seemed like the right thing!
Offline thiggy
Re: What are these
« Reply #7 on: September 16, 2014, 12:45:05 PM »
Weatherhead it is.  It screwed to the side of the building and the cable from the pole entered the upper holes and went down the wall to the meter.
