Author Topic: What the hell are these things  (Read 21293 times)
Re: What the hell are these things
« Reply #45 on: September 02, 2014, 06:00:46 AM »
Apparently one wasnt enough for this guy, all 3 marked Mac SC 105 Google and E-bay are not helping identify. 3/8 drive and impact sockets of some sort?
How about these, I did add better pictures later in this thread.
« Reply #46 on: September 02, 2014, 06:01:30 AM »
Made by Industro. Spring loaded lever pushes out what looks like a feeler gauge which comes out of a socket end. The other end has two little tangs with a hole in the center.
Any ideas on this one?
Offline leg17
« Reply #47 on: September 02, 2014, 09:16:16 AM »
Your five threaded "thumb screws" look an awful lot like adapters for a clutch alignment tool.
Do you have another piece with a threaded hole that these fit?
« Reply #48 on: September 02, 2014, 10:15:24 AM »
Lower left, could this be a valve tool?
Right side patent number 3, 807,530 I get nothing using google
Top: Not sure why he collected these ( what I call ) thumbscrews. There may be more out there.
Can someone confirm that the lower left tool is indeed a battery tool?
I don't think it is - what do you think it can do to a battery?
It is a bearing press. I have a similar one that attaches to one of my pullers.
« Reply #49 on: September 02, 2014, 05:16:55 PM »
Weird, the design is like a pitman puller, but that wimpy handle isn't gonna work for that.
« Reply #50 on: September 02, 2014, 07:22:51 PM »
I do not think I did, other people raided the tool box that I own now before I got to it so who knows.
« Reply #51 on: September 02, 2014, 07:29:04 PM »
Heres a couple more shots, maybe these will help. The forks are beveled so maybe they are made to slip under something like a battery terminal and screw down the screw to pull the terminal free.
I do not think press cause as Rusty said the handle is pretty wimpy. Length of handle is 4 inches if that helps size it up.
« Reply #52 on: September 02, 2014, 09:02:38 PM »
I also think it is a battery cable lifter,  they do not need much pressur at all,
somewhere I have one that is sorta like that,  I have a few of the old long handle type
that works the same way.
the screw will not move the battery post, the cable will lift 1st.
Frank
« Reply #53 on: September 03, 2014, 06:01:48 AM »
Frank
Amecks is the originator of this theory. I never would have guessed myself.
« Reply #54 on: September 04, 2014, 05:02:53 AM »
This has been identified by someone on garage journal as a .......... joel63
Senior Member
joel63's Avatar
Default Re: Can someone identify this
Quote:
Originally Posted by hippie2cams View Post
I think that is an old distributor tool the end with the feeler gauge is for the points, the end with the tabs is actually a screw driver for the screws in the distributor holding the points and condenser. I have not seen one in a long time so its possible I'm wrong.
A Delco distributor tool for early model Chevy 6 cylinder engines.
Maybe a little different?
http://www.ebay.com/itm/Snap-On-MD17...-/121298921364
Google Snap On MD17.
« Reply #55 on: September 04, 2014, 02:40:28 PM »
Frank
I think Frank is right also, your newer pictures totally changed how I saw the tool.  I was imagining it bigger.
« Reply #56 on: September 04, 2014, 03:00:04 PM »
Frank
I should use a scale of some sort
« Reply #57 on: September 13, 2014, 08:43:45 PM »
the tool that 1930 posted and we thought that it was a top post battery cable lifter.
that is correct.
Rose tool catalogs.  Craftsman 1968 shows the exact one, it was called battery terminal lifter $2.19
Frank
Offline Ietech
  • "OLD GUYS RULE"
« Reply #58 on: September 14, 2014, 10:24:52 AM »
Can anyone provide a picture of the pullers assembled, maybe then I can pinpoint the missing pieces.
Hope this helps for a couple of the Items you have, see link below
http://www.grainger.com/product/OTC-Puller-Set-4HA44
« Reply #59 on: September 14, 2014, 12:53:56 PM »
If the "thumbscrews"  are lug nut sized, they may be for pulling/pushing brake drums.
(screw them into the hub flange so you have something to push/hammer on)
Three would be the right number sometimes...
