Author Topic: Today's Finds  (Read 1765 times)
Offline Wrenchmensch
Today's Finds
« on: August 18, 2011, 04:26:15 PM »
Hunting today at a flea market produced these two wrenches. One is a small 4 3/4" J H Co (Johnston Harvester Company) wrench with a 3/4" opening. It has the number 1096 embossed on its backside.
The larger wrench is a double open-ended wrench with Jas. Clayton embossed on it. Its hex openings are 1" and 1 1/8". The wrench jaws 11/16" thick(!), and the wrench is 9 3/4" long. It has the number 28 embossed on its backside.  I was unable to find Jas. Clayton anywhere, and need help identifying this wrench.
Re: Today's Finds
« Reply #1 on: August 18, 2011, 04:55:33 PM »
Scientific American, may 30, 1885 lists Jas. Clayton, Brooklyn ,NY as a maker of air compressors and rock drills....
Seeger and Guernsey's [mining] cyclopædia  1899 lists
 The Clayton Air compressor works, NY, maker of rock drills...
(Other references show they made large duplex compressors, but, i dunno if they are the same Clayton, or if your wrench has anything to do with it, but it is a start anyhow......
(The Clayton Air compressor co was bought by the International Steam Pump Co ,NY, 1902 - Railway Age)
Based on a patent, Jas. seems to be James...(at least as regards air compressors)
[Which gets me an entry in The Trow 1901, James Clayton was the principal of Clayton Air Compressor Works, Cortlant st, NY]
So, the only question is, is the Clayton on your wrench the same Clayton.....
« Last Edit: August 18, 2011, 05:24:11 PM by rusty »
