You know, I just recently looked at a machine very much like this one. It was used to test substrate for road building. As I recall, you put a wet sample of the substrate in the bowl and turned the handle. After vibrating the bowl for a specified time, you measured how far it had pulled away from the edge and could extrapolate from that how the material being tested would work to build a road on.
