Author Topic: Sometimes, when you make it to the bottom of the bucket...  (Read 4218 times)
Offline kxxr
« on: August 10, 2011, 08:34:55 PM »
You find a nice hex universal. Usually not though. Also, from the same barrel, 3 screwdrivers with moving parts and an X branded offset. Only one is a whatsit though. The top screwdriver is Vaco K44 (is it missing a sleeve?). Next is a "ReadyWedge, Salt Lake City" and the last is a whatsit. It says Hunter 10 and when you push the shaft into the handle, a small bit of metal reveals itself, perpendicular to the blade, making it + shaped, with one cross on the + being much shorter. What is that for?
« Last Edit: August 18, 2011, 06:55:06 AM by kxxr »
lzenglish
  • Guest
Re: Sometimes, when you make it to the bottom of the bucket...
« Reply #1 on: August 10, 2011, 08:59:15 PM »
It serves the same purpose as the other captive screw drivers, in that it binds in the slot of the screw head.
Wayne
« Reply #2 on: August 10, 2011, 09:02:23 PM »
Those were used to hold the screw on the driver as you went toward the threaded hole. The split blades would hold against the flats of the screw and keep it on the driver. The second one may have had a sleeve which when pushed forward, closed the two blades, and when pulled back, let them open up against the flats. They were really just screw starters, not for putting any torque on a screw.
lzenglish
  • Guest
« Reply #3 on: August 10, 2011, 09:21:05 PM »
I have found these screw starters will snug up to about a #10 machine screw, with enough torque. And, they sure beat the bubble gum/tar/wax,etc. stick on methods that I still use when I can't find my starter.! Lol !
Wayne
Offline RLT
« Reply #4 on: August 10, 2011, 09:26:48 PM »
The K 44's I had all had the sliding sleeve, VACO was my preferred brand when I worked electrical.
Offline kxxr
« Reply #5 on: August 11, 2011, 06:45:28 AM »
I thought the Vaco might be missing a part. Probably still making it's way to the bottom of the bin I took the screwdriver from.
The sleeve on the second one is still there, it slides down just as described by papaw.
The 3rd one, the Hunter, I still don't really get. The spring inside is so stiff that you have to put a good 5-6 pounds of downward pressure on it to activate the device. Not good for screw starting I wouldn't think.
But hey, how 'bout that universal ... no comments from y'all, but I thought that was quite a find.
Offline Fins/413
« Reply #6 on: August 11, 2011, 06:52:41 AM »
Looks like the bottom of the bucket was good to you.
1959 Chrysler New Yorker
1982 E150 Ford van
lzenglish
  • Guest
« Reply #7 on: August 11, 2011, 07:55:20 AM »
We aim to please here on tool talk, so "I'll Take It"! Lol  Seriously though, if you want to part with it, please PM me.
Thanks,
Wayne
