Author Topic: Old RCAF Wrench - Terry's Spanners  (Read 7277 times)
Advan
  • Guest
« on: June 10, 2014, 06:41:41 PM »
I found this wrench in Grandad's old tool chest.  There isn't much question as to what it is (obviously lol), but has anyone seen anything like it before?  I sure haven't.  It seems to be in remarkable shape, with only the 1/2" end showing any signs of use.     Thanks for taking a look guys!
Re: Old RCAF Wrench - Terry's Spanners
« Reply #1 on: June 10, 2014, 07:34:37 PM »
« Reply #2 on: June 10, 2014, 08:08:15 PM »
RCAF = Royal Canadian Air force
note the whitworth sizes
sarah?? I dunno
Skip
« Reply #3 on: June 21, 2014, 07:40:21 PM »
SARAH - Search And Rescue And Homing Equipment ...
Offline bear_man
« Reply #4 on: June 21, 2014, 11:55:11 PM »
Hmm.  That says to me that the Brits would/could call ANY open-end wrench a "spanner."  Looks like yer standard DOE to me.  I'd learned when young that a "spanner" has an open arc (on one end of a straight handle) with a "hook" at one end of the arc to snag one of the ears on, say, a fire hose fitting.  No "tight/smooth fit" required, like is needed on battery cable nuts.
  • Administrator
« Reply #5 on: June 22, 2014, 12:02:49 AM »
We would call that a spanner, but Europeans use spanner for wrenches. Crescent types are called "shifting spanners".
« Reply #6 on: June 22, 2014, 05:15:57 AM »
We have open ended, ring and combination spanners - as well as adjustable spanners (also called monkey wrenches) - pipe spanners are often called by maker's names, e.g. Stilson or Footprint (c.f. Hoover for a vacuum cleaner)...
Mind you, you call the boot of a car the trunk, and the bonnet the hood - and you have gear shifts instead of gear levers...
And mis-spell theatre, metre, colour, flavour and lots of other words... see: http://en.wikipedia.org/wiki/American_and_British_English_spelling_differences#-our.2C_-or
  • Administrator
« Reply #7 on: June 22, 2014, 07:02:10 AM »
Quote
Ah, the different English we use!
« Reply #8 on: June 22, 2014, 07:47:58 AM »
Can't come up with a list of them, but a number of spelling differences come early in American English (plow vs plough is one, jail vs gaol is another) and were deliberately done, just to be different from the English.
« Reply #9 on: June 22, 2014, 01:23:27 PM »
We showed them!
« Reply #10 on: June 22, 2014, 08:08:42 PM »
yes, I agree that we/they have strange words.
back in my younger days, I had a 1953 MG-TD and the manual drove me nuts.
their use of the word earth took a while to sink in that they were referring to what
we call GROUND.  as in electrical wire ground.
they were right, as they built that car.
  • Administrator
« Reply #11 on: June 22, 2014, 08:47:49 PM »
And it was POSITIVE to earth, not negative!!!! :huh:
« Reply #12 on: June 22, 2014, 09:16:58 PM »
Are you positive?
  • Administrator
« Reply #13 on: June 22, 2014, 09:56:49 PM »
Several Triumph and BSA motorcycles and a couple of MGAs- Yes I'm positive, and the battery on the MGA was under the floorboard in the back seat area.
All wiring by LUCAS- The Prince of Darkness!
« Reply #14 on: June 23, 2014, 07:32:03 AM »
Yeah, positive ground.  I remember back in the day that you were supposed to check the battery terminals for positive and negative before putting on jumper cables, since some vehicles used positive ground, and a mistake was a bad idea.
