Author Topic: Is this Planet Jr Desireable?  (Read 5075 times)
« on: May 27, 2014, 02:06:48 PM »
Anything special about this?
Bid on, but was quickly outbid - somebody really wants it...
Re: Is this Planet Jr Desireable?
« Reply #1 on: May 27, 2014, 02:41:10 PM »
I can' tell from the picture, but if it is a K48 then yes.  This was the smallest one they made and are somewhat scarce.
On the other side is where you will find the K48.  They are about 5" long.
« Last Edit: May 27, 2014, 04:55:56 PM by mikeswrenches »
« Reply #2 on: May 27, 2014, 02:58:48 PM »
The other side has a 3 on it by the box end.
« Reply #3 on: May 27, 2014, 05:04:49 PM »
The cut-out's are less common than the solid ones but not rare.  The solid ones bring around $5 and the cut-outs around $20 more or less.
Bus or Stan would have a much better idea.  As I remember(a problematic thing at best) there is a larger one that has two hammer polls that is the least common of all.  I have never seen one of them.
« Reply #4 on: May 27, 2014, 05:22:17 PM »
Thanks Mike
« Reply #5 on: May 27, 2014, 05:45:33 PM »
Isn't the K48 a DOE?
« Reply #6 on: May 27, 2014, 05:55:54 PM »
Les, it is indeed.  Just looked at mine.  Not sure what I was thinking.   :rolleyes:
« Reply #7 on: May 27, 2014, 09:12:01 PM »
I just picked one up for $4 that is the only way I thought I was correct on that one.
Offline mvwcnews
« Reply #8 on: May 28, 2014, 09:06:12 PM »
PLANET JR. / 3 is relatively common.    The one in your photo is slightly bent in the shank, but not rusted or pitted, or sporting any broken or cracked letters.
 The 12" long PLANET JR. 312 is the rarest -- kind of on the Biblical "pearl of great price" plane of being.
Offline Carl Wagner
« Reply #9 on: May 29, 2014, 10:06:51 PM »
I see the Planet Jr #3 cutouts all the time. I pass them up at anything over $5. The K48 is a tad more rare but run at less than $20 online. There is a version of the K48 marked U.S.A on the back that fairly hard to find.
Life is hard. Its harder if your stupid.- John Wayne
Offline Wrenchmensch
More Planet Jr. cutouts, but not all
« Reply #10 on: June 09, 2014, 10:56:41 AM »
Here are some Planet Jr. cutouts I have found so far.  Finding the large H4 took the longest time.
