Author Topic: Message problem?  (Read 4543 times)
Message problem?
« on: May 11, 2014, 09:17:50 PM »
Hmmm, I've been away for a few days, and now I can't read my messages. When I click either "Read Your Messages" or "Send A Message" then a blank page comes up with this error displayed:
Fatal error: require_once() [function.require]: Failed opening required '/home/content/02/7786002/html/vboard/Sources/PersonalMessage.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/02/7786002/html/vboard/index.php on line 358
I tried restarting my computer but it didn't help. Any other suggestions?
Re: Message problem?
« Reply #1 on: May 11, 2014, 09:29:41 PM »
papaw was working with someone upgrading the forum software. Looks like posting pictures works better. Apparently messages are now broken ;P
(Get the same error, logging out and in doesn't fix it either....)
« Reply #2 on: May 11, 2014, 09:54:28 PM »
Yes. Messages are broken at the moment. We upgraded the forum and as usual, some things are not working yet.
« Reply #3 on: May 12, 2014, 08:26:05 AM »
papaw, another thing that doesn't work is guest access :(
« Reply #4 on: May 12, 2014, 09:59:09 PM »
Guest access?
« Reply #5 on: May 13, 2014, 06:52:13 PM »
log out, like you are not a member, go to unread posts, and you get:
Warning!
Only registered members are allowed to access this section.
 Please login below or register an account with Tool Talk.
Did it do this before?
« Reply #6 on: May 13, 2014, 08:16:11 PM »
Don't know. I'll try later, but seems to me if you are a guest, all posts would be "unread".
