Author Topic: They said hay harpoon, I don't think so  (Read 5631 times)
Offline rustcollector
« on: March 29, 2014, 07:25:17 PM »
They sold this today as a hay harpoon, I think they are wrong. Doesn't open up wide enough where that seems logical. The ends are shaped like bark spuds.
Patent date is May 1, ????. I looked through all of May 1, 1900 and either missed it or it's not there.
Anybody know what it is and the patent date for sure? Each square on my floor is a foot, so that tells you about how big it is.
« Last Edit: March 29, 2014, 07:29:51 PM by rustcollector »
Re: They said hay harpoon, I don't think so
« Reply #1 on: March 29, 2014, 08:55:47 PM »
I suppose they could be Ice Tongs (648,886), tho they don't match well....
« Reply #2 on: March 29, 2014, 09:27:34 PM »
I stopped at that one too, looked for a bit and decided not. Ice tongs are always curved to reach around the block of ice. These have straight arms. It must not be 1900, I'll have to see what other years May 1st would have been a patent date.
« Reply #3 on: March 29, 2014, 09:31:18 PM »
1834,1845,1847,1849,1855,1860,1866,1877,1883,1888,1894,1900,1906,1917,1923,1928,1934,1945,1951,1956,1962,1973,1979,1984,1990,2001,
(sorry)
« Reply #4 on: March 29, 2014, 09:42:15 PM »
I never knew that people had to harpoon hay in the wild.  Shades of Moby Dick!
« Reply #5 on: March 29, 2014, 09:53:18 PM »
Can't let it get away!
« Reply #6 on: March 29, 2014, 09:54:18 PM »
Actually, I have 3 or 4 types of hay harpoons. Truthfully they are hay spears, just depends on where you are (like soda or pop).
I'd picture them but it's a long dark wet walk to the barn to get them...lol
Offline rudeawakening55
« Reply #7 on: March 29, 2014, 09:55:33 PM »
  I have one just like this one, & would say it's a hay harpoon.
« Reply #8 on: March 29, 2014, 09:57:19 PM »
Can you read the date on yours?
(sorry)
I'm liking '88 or '06 for my next run through on them. Not gonna happen tonight though. You helped me not have to figure that all out.
« Reply #9 on: March 29, 2014, 10:01:34 PM »
  I've never cleaned it up.
               Orin Lamport
« Reply #10 on: March 29, 2014, 10:05:33 PM »
If, and that's a big if, you can believe a ebay seller, he sold one and said he took it out of the barn himself. So I guess it may be just what they said. I can see where there is not a lot of them around though. I can't see where it would work very well.
« Reply #11 on: March 30, 2014, 03:41:20 AM »
Too short for a hay spear (or harpoon) - they need to be able to get to the centre of a hack rick, and with the handle are 8 to 10 feet long... this tool would only be able to penetrate a couple of feet...
What is the action, how does it open, and to what size??? Is the ring for a handle (at right angled to the axis??)
« Reply #12 on: March 30, 2014, 10:35:47 AM »
But it might work on picking up single bales, spear one open up the jaws and lift away.
« Reply #13 on: March 30, 2014, 11:19:12 AM »
Another type of device, somewhat similar, and without sharp pointed ends, are barrel tongs, used for rolling and lifting small casks....
(Can not find anything that looks like this one however)
Offline mvwcnews
« Reply #14 on: March 31, 2014, 07:58:01 AM »
To be clear, the action on this thing is it spears straight down, and then spreads its wings as you pull up, rather than grapple around the outside of a bunch.
How well this works depends on what you're using for hay.  Slick grasses or straw would not stick together well enough to spear in the middle and have a wad pull loose from the hay mow.  Tangly stuff like alfalfa or clover would stick together -- in fact you'd might have to use your hay knife to "slice" and define edges for your wad.
