Author Topic: A "what is it" farm tool  (Read 2502 times)
Offline JoeCB
« on: January 29, 2014, 08:22:53 PM »
Not sure if this belongs here or on "Farm Tools", I'm guessing that this is some kind of planting implement. The tool incorporates a hand held upper end with a spring return plunger rod extending down ot the "digging" end. The lower end is a three fingered plug cutter, the plunger rod pushes thru the core cutter to eject the (earth ?) plug. Notice the "ear" projection, this to provide a push for ones foot. The tool is marked (cast iron) "PAT - Apld - For"  "JKI" on one side and "J-R-Kovar" on the back side. Well made tool, Cast iron, steel and nice wood handles. Any ideas?
Joe B
Offline WiebeLC
Re: A "what is it" farm tool
« Reply #1 on: January 29, 2014, 10:39:05 PM »
https://www.google.ca/patents/US1647832
Here is the patent. John R. Kovar seems to have been a prolific inventor
« Reply #2 on: January 30, 2014, 03:25:17 AM »
It looks like a tool used to pull weeds. Basically you just push it down an step on it. Then pull up. The weed with root attached comes out an your done. No need to bend down, at least in theory.
Offline JoeCB
« Reply #3 on: January 30, 2014, 08:57:57 AM »
Thanks, you guys are GOO00ood! If the ground ever thaws up here in the great white north , I'll give it a try.
Joe B
« Reply #4 on: January 30, 2014, 10:20:26 AM »
Joe B
You're welcome to come over and try it at my house. I have more weeds than I do grass!
