Author Topic: Pliers? Solved  (Read 1866 times)
Offline WiebeLC
Pliers? Solved
« on: January 27, 2014, 11:24:41 PM »
These pliers are unmarked. Inside of each jaw is a groove that runs most of the length of the jaw. They are 5 1/4 inches long.
Any ideas?
« Last Edit: January 28, 2014, 12:50:15 AM by WiebeLC »
Re: Pliers?
« Reply #1 on: January 28, 2014, 12:14:10 AM »
Another set of hog ring pliers used in upholstery.
Offline WiebeLC
Re: Pliers?
« Reply #2 on: January 28, 2014, 12:49:06 AM »
Thanks!
Re: Pliers? Solved
« Reply #3 on: January 28, 2014, 04:44:49 AM »
Also used to fix wire mesh fencing to the straining wires (as well as ringing hogs) - I have just seen very similar on another forum, good quality with a boxed joint - used by jewellers to hold rings whern filing the inside (presumably after soldering - to clean up the joint)...
Re: Pliers? Solved
« Reply #4 on: January 29, 2014, 09:53:35 AM »
Jeweler's ring holding pliers are a little different, here are pictures of a pair that I have:
The groove is shallow, and the length of the pliers is 5-1/2" long.
