Author Topic: Earliest Herbrand wrench I have found  (Read 1329 times)
Offline Wrenchmensch
« on: December 13, 2013, 04:47:02 PM »
I found this 8-inch Herbrand wrench today in the litter on my workbench. The openings are 15/16" (closed end) and 1/2" (open end).  It looks, from the typeface on the bosses, that the wrench was produced sometime before 1900.  It also appears to have been finished on a Monday, or by a novice.
The letter N is backwards in the words Herbrand and Fremont.  Also, the number 993, was botched during the embossing step.
The wrench appears to be designed for a specific purpose. Does anyone know what that was?
« Last Edit: December 15, 2013, 04:42:31 PM by Wrenchmensch »
Re: Early Herbrand wrench
« Reply #1 on: December 13, 2013, 06:50:49 PM »
This is ringing a bell, but I cant quite get it.
could it be late enough to be a 'ford' wrench?
Skip
Offline leg17
« Reply #2 on: December 13, 2013, 07:57:34 PM »
The stamping is likely in the forging die.
If a limited run, then the die was not repaired and all examples probably look the same.
« Reply #3 on: December 14, 2013, 09:15:39 AM »
More information on this 993 Herbrand wrench can be found on Alloy Artifacts. It is an early spark plug wrench. Note the backward N's on the Alloy Artifact photo.  Leg 17's remarks were spot on!
http://home.comcast.net/~alloy-artifacts/herbrand-van-chrome.html#herbrand-993
« Reply #4 on: December 14, 2013, 09:26:15 AM »
If you google 933 Herbrand wrench , you find the Backwards n is common.
Some were for sale on Ebay. Stated as spark plug wrench.
