Author Topic: This came from an old service station...  (Read 3004 times)
Offline TheBigTool
« on: November 11, 2013, 01:35:32 AM »
I just got this set of tools that originally came from an old service station. Looks like a couple small wheel/gear pullers. I would love some help identifying the rest.
Offline bleonard
Re: This came from an old service station...
« Reply #1 on: November 11, 2013, 02:54:24 AM »
looks like set up tools for starter and gen. test stand
Bob
I like Starrett tools
« Reply #2 on: November 12, 2013, 09:32:02 AM »
Top right - second down - the smaller puller looks like it may be a battery terminal puller.
Al.
« Reply #3 on: November 12, 2013, 09:54:19 AM »
I believe they are both pullers for generator bearings. It might work for battery cable though.
Offline TheBigTool
« Reply #4 on: November 12, 2013, 04:23:27 PM »
Thanks for the replies. So the consensus is that Bob is right? Do you guys know if it is a complete set and what the value may be? I would like to sell it since I have no use for it.
« Reply #5 on: November 12, 2013, 06:17:29 PM »
You only have pieces used to adapt and clamp a unit to a fixture that is usually fastened solid to a bench.
We had one at an electrical shop I worked at that was made up of old lathe parts so it could be adjusted
in four directions to align the belt to the drive motor.
A lot of those pieces can be used to fabricate something else.
« Reply #6 on: November 13, 2013, 11:25:50 AM »
Battery cable pullers usually have a "pad," like a C-clamp, so you don't damage the battery post.  The jaws are also spring-loaded, so you can get it placed quickly and yank the cable end from the post efficiently.
