Author Topic: whats the name?  (Read 4859 times)
whats the name?
« on: October 05, 2013, 04:58:21 PM »
I know I've seen them but can't recollect the name.
Offline Edkat3
Re: whats the name?
« Reply #1 on: October 05, 2013, 08:35:32 PM »
May be some type of adze.
Offline chips
Re: whats the name?
« Reply #2 on: October 07, 2013, 12:24:04 AM »
Looks like an old bead breaking wedge/hammer for tires.
Re: whats the name?
« Reply #3 on: October 07, 2013, 01:05:48 PM »
I was wondering if a piece broke off, it kind of looks chewed up on the non hammer side.
Re: whats the name?
« Reply #4 on: October 07, 2013, 07:12:04 PM »
Spike adze??
Offline anglesmith
Re: whats the name?
« Reply #5 on: October 07, 2013, 08:02:57 PM »
This is certainly different, probably only it's maker knew what it was for! Looks to me like it was forged from a double faced sledge. I think that some kind of adze could be close to the mark, but I can't yet conceive what for?   On the bay it would be called a "blacksmith's hammer", but I'm sure it's not a blacksmith tool, at least I've seen nothing like it (yet)!?.  Thanks HeelSpur for challenging us.
Graeme
PS When I first saw the side view, I thought of that forester's tool called a pickeroon? That's not how it is spelt but was that what you were thinking of HeelSpur?
G
« Last Edit: October 07, 2013, 08:09:07 PM by anglesmith »
Re: whats the name?
« Reply #6 on: October 08, 2013, 07:13:48 AM »
Not that I know what it is, but it would be a pretty poor adze.  Adze blades flare out to the edge (or at least don't taper in) so they don't get stuck in when you use them.  I'd say that end was designed for prying.
Re: whats the name?
« Reply #7 on: October 08, 2013, 07:20:22 AM »
I was thinking I remember seeing one of these in making log cabins, but I could be wrong.
Re: whats the name?
« Reply #8 on: October 08, 2013, 10:04:17 AM »
Used-to-be adze hammer. Now the blade has been ground, and badly.
At least that's what it looks like to me.
 Adze hammers are pretty scarce, but they are around.
Timber construction has more use for an adze to trim wood as you go, than pulling nails, which are few if any.
Re: whats the name?
« Reply #9 on: October 14, 2013, 09:42:19 PM »
It is a journal box hammer; used on railroad journal boxes.  You can find them in Baird & Comerford.  Most of the ones that I have had have a more heavier weight peen end.
Re: whats the name?
« Reply #10 on: October 15, 2013, 06:34:24 AM »
John is correct.  I had one that was in better shape.  Sold it before I found out what is was.
Re: whats the name?
« Reply #11 on: October 15, 2013, 08:07:45 AM »
Does anyone on here know anything about railroad journal boxes and how they were used?
Re: whats the name?
« Reply #12 on: October 15, 2013, 08:54:29 AM »
Are you talking about the box for lubricant, above the bearings on RR car axles?   Early RR cars used plain bearings, then later went to roller bearings,  which required constant lubing.   Was the job of the car men to fill these on stops,  with a heavy oil.  Had a flip up iron lid.
Re: whats the name?
« Reply #13 on: October 15, 2013, 09:08:57 AM »
Here is a photo of an old Arch Bar Style RR truck.  The trainman would use the hooked end to flip the cover up and hammer in more oakum packing.  Then the packing was soaked in oil.  The hook end was probably useful when there was an overheated bearing or 'hot box'. I'm guessing the hook was used to pull the smoking or burning oakum out.
« Last Edit: October 15, 2013, 09:19:39 AM by johnsironsanctuary »
Re: whats the name?
« Reply #14 on: October 15, 2013, 02:23:39 PM »
Thanks for the info.
JMH
