Author Topic: Hand Planes  (Read 370150 times)
0 Members and 6 Guests are viewing this topic.
Offline Jim C.
Re: Hand Planes
« Reply #1290 on: March 01, 2024, 06:13:16 AM »
Navaja,
I hear you.  Writing about this stuff isn’t as easy as one may think.  Trying to keep it sort of interesting, informative, accurate, to the point, and sensible can be tricky business.  After posting a long write up, which typically took several hours to compose, I’d go back and read, and re-read, and re-read, and still re-read, for errors, clarity, etc.  That took time as well.  So, don’t worry too much about it.  Take your best shot at it and it’s all good.  If questions arise, then maybe make some edits to your post.  I can say for sure that no one here will get out of hand.  Luckily the gang here is full of vintage tool enthusiast who are very knowledgeable and willing to share their experience in a well mannered fashion.  There was one guy that used to keep me on my toes, but that made it interesting.
I’m looking forward to seeing your shop made scraper.  I used Hock blades for the cutting irons in the planes and scrapers I made. You can now find them at Lee Valley.  They’re a bit expensive but you won’t be disappointed in them.  I’d say they’re worth the investment.
Jim C.
« Last Edit: March 01, 2024, 10:49:24 AM by Jim C. »
Our Go-To Type Study Member
Offline Jim C.
Re: Hand Planes
« Reply #1291 on: March 07, 2024, 02:54:15 PM »
Just a few posts above, we were briefly discussing a couple scraper planes that I made out in my shop.  Making the planes is fun and sort of rewarding when there’s an opportunity to use them successfully on a project.  Over the years, I’ve come to know that when working with cherry, there’s a very good chance that I’ll get a burn mark or two on the surface of the wood.   It seems like cherry is really prone to getting burned no matter how careful one may be.  It’s unsightly, and can ruin the aesthetic beauty of the grain immediately. While there are likely several ways to eliminate those burn marks, my favorite “burn buster” is a scraper plane.  Outfitted with a thick, well sharpened iron, a scraper plane can remove those burns easily.  When using, I like to pull the scraper towards me, versus pushing it, like is done with other planes.  If the plane is set up correctly, the user should be peeling off less than paper thick shavings that are like fine lace and float to the floor.  In just a few pulls, the burn marks are gone and the beauty of the grain is restored.
Jim C.
« Last Edit: March 08, 2024, 10:12:26 PM by Jim C. »
Re: Hand Planes
« Reply #1292 on: July 27, 2024, 02:13:49 PM »
Looks similar to Japanese planes.  They pull their hand planes. Nice work!
Offline Jim C.
Re: Hand Planes
« Reply #1293 on: August 29, 2024, 04:28:01 AM »
Hello hand plane enthusiasts!  I hope everyone is well and enjoying some sort of woodworking activity that involves using at least one or two planes.  I very recently completed a small wall hung cabinet that has a door and two drawer fronts made from one panel that consists of several (18) strips of 1/4” thick, varying types of wood.  The strips are different heights, and faced glued together, showing the long edge of each strip of wood.  Consequently, when faced glued, the difference between the heights of each strip created valleys, and of course some glue squeeze out.  As hard as I try to use just the right amount of glue, I almost always get some squeeze out.
Well, in this particular instance, I used a Stanley #238 outfitted with 1/4” wide cutter to clean the excess glue out of each valley.  Worked like a charm.
Jim C.
« Last Edit: August 29, 2024, 06:21:05 AM by Jim C. »
Re: Hand Planes
« Reply #1294 on: August 29, 2024, 11:23:13 AM »
Nice job!  I like the design and implementation.
Offline Jim C.
Re: Hand Planes
« Reply #1295 on: August 29, 2024, 11:38:02 AM »
Hey Yadda,
Thanks for checking out my project.  I hope I was able to demonstrate another way to use those weather stripping planes.
Jim C.
Re: Hand Planes
« Reply #1296 on: August 30, 2024, 08:50:48 PM »
Hello, Jim C. Stunning work , once again! Great use of the Stanley 238!!
Offline Jim C.
Re: Hand Planes
« Reply #1297 on: August 31, 2024, 04:39:05 AM »
Many thanks Lou!
Jim C.
« Last Edit: August 31, 2024, 04:41:28 AM by Jim C. »
