Author Topic: Rockwell Model 75 Circular Saw  (Read 19038 times)
Re: Rockwell Model 75 Circular Saw
« Reply #15 on: April 17, 2015, 12:02:10 PM »
I've successfully switched out some blades by clamping one of those trigger-type bar clamps (see image below) on the blade, letting the blade rotate to the point that the clamp was wedged against the baseplate, then applying the wrench.
Striking the wrench end a sharp blow with a moderate-weight hammer helps to get it started.
« Reply #16 on: August 20, 2015, 04:34:57 PM »
Hello, I have found that the ultimate tool for freeing up a blade bolt or star washer is an impact wrench with the appropriate size socket. Good luck, Lou
« Reply #17 on: August 21, 2015, 05:44:44 PM »
Bill, I like your solution a lot.  Of course I could put some wood in the jaws of my new Record vise (ahem) and clamp the blade in that.
« Reply #18 on: September 01, 2015, 09:03:08 PM »
I went back and looked at the first post here, and am mildly amazed that we built a two-page thread out of this:
Of course, we did digress a bit...
