Author Topic: thingy  (Read 3887 times)
Offline benjy
thingy
« on: July 24, 2011, 09:13:45 AM »
i am sure you guys  have identified one of these before,but i cant remember,,ratchets in one direction.
Offline strik9
Re: thingy
« Reply #1 on: July 24, 2011, 01:42:11 PM »
That is a drill ratchet, there would be a frame that would press it down as you ratcheted the bit into the stock.  Used on naval ships because thats where I seen the info.  An old navy training manual.
Offline Wrenchmensch
Re: thingy
« Reply #2 on: July 25, 2011, 02:00:45 PM »
I've had a couple of these.  Machinists used them to locate holes correctly, centered  on a hole in an adjoining surface parallel to the one being drilled.  I've had ones made by Pratt & Whitney and others that have been shop made and have wooden handles.
