Author Topic: What is this?  (Read 3785 times)
PG
  • Guest
What is this?
« on: May 04, 2013, 03:43:53 PM »
http://tinypic.com/r/n4e3q/5 - this link is to a picture of a tool or weapon that I have- It appears old and hand made. It is on a long pole like a shovel handle. Can anyone identify it? Thank you
« Last Edit: May 04, 2013, 06:06:00 PM by Papaw »
Re: What is this?
« Reply #1 on: May 04, 2013, 08:50:50 PM »
First thing that comes to mind is a firemans tool, for ripping into a roof or siding, probably 100+ years old.  Never was on the fire dept.
Re: What is this?
« Reply #2 on: May 04, 2013, 09:05:54 PM »
How about a blacksmith made loggers peavey?
Offline RWalters
Re: What is this?
« Reply #3 on: May 04, 2013, 10:57:11 PM »
From what I could find, it's an ice hook, used to move blocks of ice when cutting them on the pond or moving them around later in the icehouse. The examples I could find pictures of were made by the Gifford-White company and were so marked along the long leg of the curved piece. Apparently Gifford--White made all sorts of ice handling tools.
Re: What is this?
« Reply #4 on: May 04, 2013, 11:27:49 PM »
My first thought was a user made climbers ice axe, but after reading RWalters post I would think that his idea would be more like it. It makes sense that this wood be a good tool to move the cut blocks around on the ice and possibly in an ice house.My father (originally from Manitoba) told me they used to put a layer of sawdust betweeen the blocks to prevent them from freezing together in the ice house, but I think that this looks like a great tool to move the blocks around out on on the ice prior to loading them on a skid. My dad also told me they had a gin pole rigged on the back of the ice skid to lift up and stack the blocks but he never mentioned how they moved the cut blocks around on the ice. This looks like it would sure work for that pupose.
Re: What is this?
« Reply #5 on: May 05, 2013, 10:17:31 AM »
I picked one of these up at a garage sale in Long Lake, NY a couple years ago.  It was definitely used to move blocks of ice around.
I think you'll find that it is the Gifford-Wood Co. rather than Gifford-White.  The link below will give you a little history on the G-W Co.
http://gossipsofrivertown.blogspot.com/2012/10/hudson-in-1905-part-45.html
Offline Mel Larsen
Re: What is this?
« Reply #6 on: May 05, 2013, 11:35:26 AM »
Looks like a Viking's best friend.
Re: What is this?
« Reply #7 on: May 05, 2013, 05:06:29 PM »
I don't know, but if I met someone holding it, I sure wouldn't argue with him/her.
Offline RWalters
Re: What is this?
« Reply #8 on: May 06, 2013, 12:15:11 AM »
@mikeswrenches Right you are, it's Gifford-Wood, not Gifford-White. I'm going to blame that one on auto-correct!
Offline Batz
Re: What is this?
« Reply #9 on: May 06, 2013, 01:50:05 AM »
Yep, that thing gunna hurt.
Re: What is this?
« Reply #10 on: May 08, 2013, 08:15:11 PM »
Pretty much the same tool was also used for moving around logs during rafting.  They are listed in Sellens as pike, pick poll, or pike pole.  I always called them pike poles.  The hooks on the ice ones (I think your is one of those) usually look more like the spikes on an ice ax.  The hooks on the pike poles I have had are often more rounded.
Offline amertrac
  • ny mountain man
Re: What is this?
« Reply #11 on: May 09, 2013, 05:01:13 AM »
I used one for years to roll logs while cutting firewood but they were called ice hooks .a peavie hook and cant hook are different  bob w.
