Author Topic: Early wood bits, but the forked one?  (Read 3972 times)
0 Members and 12 Guests are viewing this topic.
Offline superzstuff
« on: April 24, 2013, 10:32:58 AM »
Bought a nice group of wood working bits with Sorby, B.Botson, J.Howarth, and Colouhoun & Cadman names. I like the jester graphic on the Sorby bits. I have an idea what most are for but the C & C forked one, I'm not sure of use.
Offline Neals
  • Alberta, Canada
Re: Early wood bits, but the forked one?
« Reply #1 on: April 24, 2013, 11:08:32 AM »
Can't tell from the pictures but it could be for lapping valves. Some old valves had 2 holes in the top that the pins fit in.
« Reply #2 on: April 24, 2013, 11:22:10 AM »
It is for turning split nut handsaw nuts.  I cannot remember the exact patent date when the modern nuts were invented; 1872 or 1873.  Prior to then, the screw went through the end of the nut.  The Disstonian Institute website has a good breakdown of it.
Offline superzstuff
« Reply #3 on: April 24, 2013, 11:38:43 AM »
Tips do look like very thin screwdrivers. I looked up C & C and not much on them just a few other wood working tools.
Offline tucker
« Reply #4 on: April 24, 2013, 01:38:35 PM »
b.botson,could be ibbotson edge tool maker sheffield.as stated that bit is for
split nuts on saws.
« Reply #5 on: April 24, 2013, 03:04:46 PM »
Joining the chorus here; definitely a split nut driver.  Yes, for saw handles.  Here's a picture of some spanking new ones.
« Reply #6 on: April 24, 2013, 03:08:11 PM »
By the way, at least as late as the 1980s those center bits were still in production by Peugeot's hand tool division.
« Reply #7 on: April 24, 2013, 03:14:05 PM »
Tucker, I think you're on the money here.  Ibbotson was an excellent manufacturer.
« Reply #8 on: April 24, 2013, 05:02:54 PM »
Center bits are outstandingly effective bits! They don't drill super deep holes well, but how often do you really need a hole over 2" deep?
 I saw some Japanese center bits made for power drills, in the 90's!
  The real whatzit to me, is the top bit in the rt column? I can't see it clearly enough but it looks weird to me!
 The one that looks like a diamond on the end is for metal, and of course reamers and countersinks.
 But that top rt??
Offline superzstuff
« Reply #9 on: April 24, 2013, 06:49:14 PM »
That is the only one marked Botson and I assumed it was a screwdriver. It has a very thin flat end.
« Reply #10 on: April 26, 2013, 09:25:49 AM »
Yeah they are!  I have a bunch of the center bits, and I do use them.  Not for deep, as you say, but they're quick and clean and they don't mind if part of the hole is off the board.  Great for drilling end grain, too.
I still have a set of those Japanese bits that I bought in the '60s.  There may have been other manufacturers.  Eric Sloane mentioned these reinventions of the center bit, in A Museum of Early American Tools I think.  May have been in A Reverence for Wood.
