Author Topic: Delco Light Plant Wrenches  (Read 15776 times)
Offline leg17
« on: April 14, 2013, 12:41:34 PM »
I have seen the usual five Delco Light Plant Wrenches.
(I am omitting any mention of small ignition or magneto style wrenches for this post.)
No. 28248 and No. 28282, both marked "DELCO LIGHT PLANT"
Also No. 90257, 90258, and 95095, all not marked Delco but understood to be.
All five have some usage marked on both sides such as: "Connecting Rod", or "Spark Plug", or whatever.
I have recently seen another wrench No. 96080, though the numbering is not crystal clear.  Could be 95080 or something else.
It certainly looks like it belongs with the others.
A closed hex opening at each end.
Usage is "BASE PLATE SCREWS" and "MOTOR MOUNTING SCREWS".
Sorry, no picture capability at the moment.
ANYONE EVER SEEN OR HEARD OF THIS WRENCH?
Is this a sixth Delco Light Plant Wrench?
Re: Delco Light Plant Wrenches
« Reply #1 on: April 20, 2013, 03:02:38 PM »
A few years ago i had a Delco little Joe light plant ( generator). Delco is short for Detroit Light Company. I have since sold it, but may still have some pictures of it.
Offline leg17
« Reply #2 on: February 09, 2015, 01:14:44 PM »
BUMP
Offline mvwcnews
« Reply #3 on: February 09, 2015, 01:22:00 PM »
Pg. 11, Sept 2008 MVWC Newsletter was devoted to DELCO wrenches & noted BASE PLATE / MOTOR MOUNTING SCREWS  96080  among the others.
Offline leg17
« Reply #4 on: February 09, 2015, 04:22:35 PM »
Thanks so much.
Can I access that online?
« Reply #5 on: February 09, 2015, 06:57:13 PM »
Id like to see some pictures
Offline mvwcnews
« Reply #6 on: February 10, 2015, 06:29:32 AM »
Thanks so much.
The MVWC Newsletter is still a hard copy only critter -- photocopied from a "master."  The club's whole web presence needs major work. -- Stan Schulz, Newsletter Editor
Offline Bus
    • The Wrenchingnews
« Reply #7 on: February 10, 2015, 11:13:57 AM »
Here's a list I compiled a few years ago.
                                                    List of Delco Wrenches and Possible Delco Wrenches
28248 - Spark-Plug / Generator Delco-Light
28282 - Armature Pull Nut / Cylinder Stud Nut Delco-Light (8")
70217 - Timer Wrench (1943 Delco/Sears Light Plant & Pumps Parts List) Not pictured and  1926 Distrubutor Wrench (Delco
              Models 750 and 755 Plants Parts List) pictures small doe ignition wrench with gauge.
90257 - Spark Plug - Gen. Nut / Cylinder Stud - Battery Nut (8") (1943 Delco/Sears Light Plant & Pumps Parts List) and (1926
             Delco Models 750 and 755 Plants Parts List)
90258 - Conn. Rod Nut / Cyl Head - Cover Plate (7.25") (1943 Delco/Sears Light Plant & Pumps Parts List)
90258 - Conn. Rod Nut / Cyl Head - Cover Plate. Variant  (7")
90258 - Marked with number only. 7"
90569 - Conn. Rod Nut / Cylinder Head Screw (7.25")
93704 - Primer Plug / Cylinder & Valve Plug double open end (10.25")
93704 - Primer Plug / Cylinder & Valve Plug double hex box  (10.25")
95095 - Cylinder Nut / Connecting Rod Screw (8.5") (1926 Delco Models 750 and 755 Plants Parts List)
95961 - ECCENTRIC & GEAR NUT 95961 / Connecting Rod Screw (Bob Wickes had on ToolTalk Aug 12, 2013
96080 - Base Plate Screws / Motor Mounting Screws (7")
R752  - Spark Plug - Gen. Nut / Cylinder Stud - Battery Nut
« Last Edit: February 11, 2015, 01:13:34 AM by Bus »
Offline Bus
    • The Wrenchingnews
« Reply #8 on: February 10, 2015, 11:17:36 AM »
More photos of my Delco wrenches
« Last Edit: February 10, 2015, 06:03:55 PM by Bus »
Offline leg17
« Reply #9 on: February 10, 2015, 02:01:05 PM »
Gosh Bus thanks so much.
I really appreciate this info.
Thanks.
« Reply #10 on: February 11, 2015, 12:42:51 AM »
Try the generator board on smokstak.com
Offline leg17
« Reply #11 on: December 29, 2017, 04:00:08 PM »
I have found a wrench that is clearly marked 90559.
It appears to be similar to the one identified as 90569 but appears to be 90859 in the photo.
The one I have has the right angle socked ‘equalized’ rather than offset like the one in the photo.
It is about 7.25 OAL and both sockets are about 3/4.
What exactly is pictured above?  90569 or 90859 or ???
What exactly do I have?  A variation of the above, (like the 90258 wrenches)?
Or is this something else?
« Last Edit: December 29, 2017, 07:48:05 PM by leg17 »
Offline leg17
« Reply #12 on: December 29, 2017, 07:50:59 PM »
Some of the Delco wrenches were apparently made by Dayton, and have a circle around the letter D for a logo.
The 90258 wrenches have a logo that looks somewhat like a maltese cross.
Does anyone know who the manufacturer of those 90258 wrenches could be?
Can anyone provide a copy of "Pg. 11, Sept 2008 MVWC Newsletter devoted to DELCO wrenches"?
Thanks
Tom
Offline mvwcnews
« Reply #13 on: January 04, 2018, 12:21:22 AM »
RE pg.  11, Sept 2008 MVWC Newsletter -- the lists & photos supplied by "Bus" in this discussion thread  are better than that long ago page.
Offline leg17
« Reply #14 on: January 04, 2018, 05:35:05 AM »
Thanks Stan
