Author Topic: What Is This??  (Read 14533 times)
Offline Dave Arnett
Re: What Is This??
« Reply #30 on: February 22, 2013, 01:29:21 PM »
I sent it here  http://www.northhouse.org/
They had no idea either.
Still diggin' though.
Re: What Is This??
« Reply #31 on: February 22, 2013, 09:15:33 PM »
You can buy yourself a 580 Case tractorhoe, it's still a clamping device for holding rings while they are being buffed or worked on.
BTW, mortise & tenon are line drilled in place, and a peg larger than the hole is driven in.
Offline Dave Arnett
Re: What Is This??
« Reply #32 on: February 23, 2013, 09:11:10 AM »
"...it's still a clamping device for holding rings while they are being buffed or worked on.
Is there some way to substantiate that?
I'm not going to the museum and telling them, "It's a clamping device for holding napkin rings while they are being buffed or worked on. I know this for a fact because 'cause Aunt Phil told me so."
They're gonna want more than that.
Re: What Is This??
« Reply #33 on: February 23, 2013, 01:30:45 PM »
Gee Dave, had you only mentioned Museum to begin with, I would have told you it's a time honored  well known device for expanding the discharge port on Curators & members of museum exhibit comitys.  My experience over a number of years with those vaunted people tells me they all know everything and need expansion to prevent fissures when they expound and enlighten with misinformation.
The model in your picture predates the exploding wedge unit that killed a lot of comity members which has been replaced currently with a hydraulic device from Enerpac.
Offline Dave Arnett
Re: What Is This??
« Reply #34 on: February 23, 2013, 04:45:31 PM »
STILL DIGGING
Re: What Is This??
« Reply #35 on: February 24, 2013, 04:34:00 AM »
Mortice drilled through, tenon marked and hole drilled closer to shoulder so when drawbore pin, or dowel, is driven in it pulls joint tight and pre-tensions it. In Europe dowels are usually hand cut and tapered to a dull point... Yes body of dowel can be slightly larger than the hole, but it needs the point to get it through three holes, only two of which are in line.... Most dowels are hand cut, so tend to be polyagonal, not round - they bite into the wood, and as both hole and dowel are compressed slightly they do not come loose..
Images from: http://portugalpermaculture.blogspot.co.uk/2011/07/sills.html
« Last Edit: February 24, 2013, 04:46:32 AM by Billman49 »
Offline amertrac
  • ny mountain man
Re: What Is This??
« Reply #36 on: February 24, 2013, 05:00:51 AM »
It's probably going end up as part of a childs homemade toy LOL   BOB W.
Re: What Is This??
« Reply #37 on: February 24, 2013, 07:41:44 AM »
Yes, just so.  Some are even left square at the outside end of the pin.   You can see the point of the points in a lot of old barn construction.  The big ones used in timber framing are called trunnels (tree-nails).  In furniture, the  shoulders of the tenons are frequently undercut to make a knife-edge joint.  In old window sash, the pins are usually polygonal.  Better gripping that way.
Offline Dave Arnett
Re: What Is This??
« Reply #38 on: February 24, 2013, 11:14:49 AM »
Thanks for the constructive feed back, Gentlemen.
At this point, I'll research almost any suggestion.
The curator of the museum (a very knowledgeable, well respected gentleman) suggested that the small end may be worn smooth because it's the handle, rather than the working end. I'm not sure if I'm buying that or not, but.........who knows?
I hope not, but that could very well be the case, Bob.
STILL DIGGIN'
Offline Dave Arnett
Re: What Is This??
« Reply #39 on: February 26, 2013, 08:13:01 AM »
I just got this...
I think that this is a wedge that was used in rope beds to roll the tension at one end of the bed before the weaving took place of the crossings that were directed through the sides and ends of the bed. When this peg was in place in the hole with the line tied around it, the wedge was driven in and, because they did not want the peg to split, they put the iron ring on the peg top. I am not certain however.
Watcha think?
Re: What Is This??
« Reply #40 on: February 26, 2013, 09:14:46 AM »
Makes sense to me.
Offline Dave Arnett
Re: What Is This??
« Reply #41 on: February 26, 2013, 01:49:50 PM »
Just got this from a "rope bed guy"....
Hi Dave,
Sorry, I have never seen one of these.  Sounds like it over complicates what simply a knot would do.
Good luck in your search!
Mark
Weaving Haus Antiques
Back to diggin'!
Re: What Is This??
« Reply #42 on: February 26, 2013, 02:04:39 PM »
Send $1000 honorarium to Distinguished Professor Philippe DeBlanc Endowment Fund and the Prof will write you a short book on the ring holder, why it's built with a wedge instead of a screw, and how it's used.
I'll even include a picture of a shovel, and instructions on how to employ the ring holder to expand a curators information portal.
Offline Dave Arnett
Re: What Is This??
« Reply #43 on: February 26, 2013, 03:07:31 PM »
I haven't been here long, but (with all due respect) I have been here long enough to learn you're the kinda guy that "I'd like to buy for what you're worth, then sell you for what you think you're worth." ;)
Re: What Is This??
« Reply #44 on: February 26, 2013, 05:20:42 PM »
Snicker ;P
Still, I am leaning towards Phil's idea it is a holder for polishing....
It resembles several other things I have seen for similar purposes, unfortunatly, the jewelry and silver trade practiced secrecy to the point of paranoia, and there is very little good documentation on methods and tools :(
