Author Topic: basin wrench  (Read 2284 times)
basin wrench
« on: January 06, 2013, 12:56:58 PM »
Anybody ever take one of these apart?
On the little plate with writing there is what I thought was a screw slot, but its just the opposite, the slot sticks out. I believe this has to be removed to disassemble the tool.
Its froze up.
Re: basin wrench
« Reply #1 on: January 06, 2013, 04:44:32 PM »
Another very neat collectible wrench
Re: basin wrench
« Reply #2 on: January 06, 2013, 08:33:39 PM »
With a really nice logo on it :)
There is a carburator tool that fits that weird inside out slotted screw (I am assuming it is a pin, and not a casting mark ;P)
(Find a junk screwdriver, cut the end off, and hacksaw a slot in it....)
Offline Bus
    • The Wrenchingnews
Re: basin wrench
« Reply #3 on: January 07, 2013, 01:25:31 AM »
It's not a real screw but a casting of the screw used to hold the name plate on the wrench. If I remember correctly you just back the adjusting nut all the way off and then the jaws just fall out.
« Last Edit: January 07, 2013, 01:29:06 AM by Bus »
Re: basin wrench
« Reply #4 on: January 07, 2013, 05:42:24 AM »
On the backside of that screw is a hole that looks like an end to a bolt, should of took a pic of the reverse too. Guess it needs a good soaking cause she's froze up tite.
Offline amertrac
  • ny mountain man
Re: basin wrench
« Reply #5 on: January 07, 2013, 07:08:32 AM »
How long is the wrench?   bob w.
Re: basin wrench
« Reply #6 on: January 07, 2013, 12:56:25 PM »
10 inches
Offline Bus
    • The Wrenchingnews
Re: basin wrench
« Reply #7 on: January 07, 2013, 01:33:47 PM »
After looking at mine there is a rivet (not a screw on mine) that holds a spring and keeps the jaws from being screwed completely out. It looks like even if you removed the rivet the jaws couldn't be removed until you get the adjustment nut unfroze.
Offline amertrac
  • ny mountain man
Re: basin wrench
« Reply #8 on: January 07, 2013, 03:51:41 PM »
Mr. spur there is a procedure to get them wheels and pins unfroze but can cause damage to the wheel. I can't recomend it . but i can tell you if you want bob w.
Re: basin wrench
« Reply #9 on: January 07, 2013, 04:45:37 PM »
OK, I'm all ears. I'd rather have it operable and a little damaged than froze up tite.
