Author Topic: My $20 Fix 1/5/13  (Read 2303 times)
My $20 Fix 1/5/13
« on: January 05, 2013, 03:51:35 PM »
Included the homemade box, which I will use to put one of the die sets in.
A Plomb hammer and a couple of nips:
The rest of the group/box:
Details:  from the top left
Sparta slip joint pliers
Barcalo DOE
Fairmount DOE
P&C slip joint pliers
Fuller stubby
Klein mini slotted
Diamond USA mini slotted
Proto long boy driver in yellow handled form
"Quick Wedge" - could not find makers marks - interesting tool I've not yet determined a use for
Craftsman Grip Driver II
Bluepoint 1214 DBE
pein hammer - unknown maker
Challenger 1/2" flex socket
Napa USA punch
Williams superrench
Keen Kutter K150 slip joint pliers
spark plug gap tool - not found makers marks yet
Nicholson file - a new one on me with the shape
Looking at the bottom left at wrenches
Proto pro 11/32 combo wrench
vlchek WC12A combo
Proto 1212 3/8" combo
Wards Master 3/16 x 1/4 DBE
New Britain 5/16 x 3/8 DOE
Bonney H16 3/8 x 7/16 DOE
Back to the bottom left:
NB-51 break-over in 3/8" drive
Proto 704 adjustable
buck knife sharpener
a couple 3/4" drive plomb sockets
Proto 2" extension in 3/8" drive
Craftsman 1/2" drive 30mm socket
Craftsman 3/8" drill chuck
Craftsman 1/2" drive extension
unknown flat stamped multi-wrench
and a couple of Craftsman V series wrenches
Offline Neals
  • Alberta, Canada
Re: My $20 Fix 1/5/13
« Reply #1 on: January 05, 2013, 05:07:02 PM »
I think that file is for ignition points. At least I have seen similar shaped ones used for that.
« Reply #2 on: January 05, 2013, 08:21:11 PM »
Nope.  That's an auger file.  The only thing that will safely sharpen auger bits.  One end has
blank edges and the other end has blank sides so you can control the cuts.
Great haul.  I can't help but notice the 4" Proto adjustable.
Offline Dakota Woodworker
« Reply #3 on: January 05, 2013, 09:06:28 PM »
Nice haul!  I've read about those auger files but have never seen one.  That little 4" proto and the 3/4" drive sockets caught my eye for sure.
« Reply #4 on: January 05, 2013, 11:46:20 PM »
Looking over this cache, was thinking, I could just about duplicate it without going out to the shop!    I just about to post about the file,,,,, just re-located mine,,, that Craftsman ratchet screwdriver turns to become a T handle doens't it?
Offline dimwittedmoose51
« Reply #5 on: January 06, 2013, 03:09:15 AM »
Nice stuff Oily,  I sent you a PM about the monkeys and the Pipes..
DM&FS
Champion Pawn/Flea Plunderer
« Reply #6 on: January 06, 2013, 03:57:35 AM »
uh huh
