Author Topic: Had a scare but I'm better now  (Read 1207 times)
Offline Scotsman1886
« on: December 26, 2012, 09:06:59 PM »
You may have seen my questions about the Williams S-51 ratchet. I got it open. Cleaned out the gunk, re greased it with lithium/moly grease. So whjat was scary?
Well I turned the selector too far while it was open. I chose not to remove it as it seemed to require the breaking or removal of a pin I was not prepared for so in not removing it I opened myself up to turning it too far.
After a search here and on google I found the patent drawings which showed a spring loaded plunger. A couple light taps with the hammer spun it around with no further damage.
The ratchet has sentemental value I am sure glad I was able to fix my mistake.
Re: Had a scare but I'm better now
« Reply #1 on: December 26, 2012, 10:26:47 PM »
Glad things worked out.
