Author Topic: ? Drill ???  (Read 4541 times)
Offline Neals
  • Alberta, Canada
? Drill ???
« on: June 26, 2011, 09:28:01 PM »
A new one to me. Handle is marked STAR. It shows a bit of mushrooming from hammer blows. The only thing I can think of is that its to drive holes in hot strap iron. But if the iron cooled you would never get it out.  Handle looks factory and so does the bit.
Offline RWalters
Re: ? Drill ???
« Reply #1 on: June 26, 2011, 10:18:09 PM »
It's a hand percussion masonry drill. Generically known as rawl drills, after the the originating company, Rawlplug, a division of Rawlings Brothers Co., Ltd. of the UK. A rawlplug is a masonry anchor invented by one of the Rawlings brothers in 1909. Originally made of jute fiber bonded with glue, rawlplugs are now made of plastic or metal depending on their intended application. Star tools made these drills as well and apparently made yours. The bit has a tapered end and will become wedged in the handle upon use, thus the cutout in the side of the tool, to insert a drift pin to knock the bit out. Use is pretty simple, insert the correct sized bit for the anchor you are using in the handle, line it up, strike the end of the handle (thus the mushrooming on your example), twist to clear dust and prevent the bit from binding, strike again, repeat until the hole is the correct depth. Missing from yours is a molded rubber, mushroom shaped guard to protect the hand holding the drill from errant hammer strikes. Who would use such a tool these days when you could do the same thing faster with a (cordless) hammer drill? Rock climbers, for one. Some of them carry a drill sized for the bolts they use to set climbing anchors and a short handled hammer to drive it.
Offline Neals
  • Alberta, Canada
Re: ? Drill ???
« Reply #2 on: June 26, 2011, 11:37:02 PM »
Thanks for all the info. I think I'll keep it as a conversation piece.
Re: ? Drill ???
« Reply #3 on: June 27, 2011, 12:51:13 AM »
Great info RWalters! Welcome to Tool Talk!
Offline pritch
Re: ? Drill ???
« Reply #4 on: July 04, 2011, 11:46:56 AM »
My Dad always called these 'Star Drills', regardless of brand. I remember him using them when I was a kid.
