Author Topic: should I know what this is ?  (Read 2983 times)
« on: October 27, 2012, 09:22:20 AM »
 Got this with some tools so I'm assuming it may be tool related. 4 inch in diameter and 2 inchs tall. Has a gasket on bottom edge that extends about 1/4 inchs from edge and is formed over the edge. I don't even have a guess. Only Marking"Burgone pat pend".
Offline Dakota Woodworker
Re: should I know what this is ?
« Reply #1 on: October 27, 2012, 11:05:39 AM »
I might be a mile off, but don't cream seperators have a series of cones like that?
« Reply #2 on: October 27, 2012, 11:08:42 AM »
I have a set of SS cones from a separator, but no slots in them.  Definitely from the food industry, being stainless steel.   Burgone googles up a lot of wine, so it may be part of a processor for grapes?
Offline Mel Larsen
« Reply #3 on: October 27, 2012, 12:25:22 PM »
I'm seeing some sort of drain guard.
Mel
« Reply #4 on: October 27, 2012, 12:39:34 PM »
BURGONE. For Deburrer for Plastic Pipe (Int. Cl. 6). First use Mar. 22, 1971
Is it sharp?
« Reply #5 on: October 27, 2012, 03:20:04 PM »
 Believe you hit it Rusty. Not too sharp,but sharp enough to remove burr from plastic pipe. Tried it on piece of 2 inch and it did the job. Probably works better on little larger pipe. Would have helped if they had called it Burrgone,or burr-gone. Wonder if they got the patent.
« Reply #6 on: October 27, 2012, 03:57:34 PM »
Looks like it, inventor matches the registrant of the trademark too..
3754832, Filed Dec 1, 1970;Issued Aug 28,1973
(Interesting as first use is claimed 1971...tsk tsk)
http://www.google.com/patents/US3754832
« Last Edit: October 27, 2012, 04:00:19 PM by rusty »
« Reply #7 on: October 27, 2012, 08:25:54 PM »
I think Rigid makes one too. it deburrs both the inside and outside of the pipe cut.
« Reply #8 on: October 28, 2012, 12:21:22 PM »
Rothenberger, which I belive is a German firm, make a similar one with a plastic body and steel blades for de-burring inside and outside of copper water pipes - 8mm to 28mm diameter
