Author Topic: Dial caliper help  (Read 5947 times)
Offline vtecboy
Dial caliper help
« on: September 29, 2012, 07:12:29 PM »
Hello,
I need a dial caliper to measure simple car stuff like brake rotors and things like that.
If you have to choose between a digital or analog dial caliper wich one would you take?
thanks
Re: Dial caliper help
« Reply #1 on: September 29, 2012, 08:16:48 PM »
Analog
« Reply #2 on: September 29, 2012, 08:56:00 PM »
Analog, but maybe because that is all I've ever had to use. I like to see the range.
« Reply #3 on: September 29, 2012, 09:25:16 PM »
Analog, because they always work, you don't have to worry about a battery, and t
hey are more dirt resistant.
but...calipers are not the right tool for measuring brake rotors..
They will measure the thickest point, you want to measure the thinnest point, you need a micrometer....
« Reply #4 on: September 29, 2012, 10:12:40 PM »
Agree with Rusty... unless you have ball tips for your caliper.  I have both, I use my analog more because it is always ready.
the digital should not be stored with the batteries installed, normally takes several button type that can leak & corrode & cost $$.
but I use digital when I want MM/IN conversion or quick check of sizes, like checking 30+ allen wrenches, unmarked, mixed odds & ends.
just press button to switch between MM or IN.
Offline william_b_noble
    • my web site
« Reply #5 on: October 26, 2012, 01:03:59 AM »
I personally have a set of the cheap chinese import brake rotor calipers, they work well for that purpose.  I take the battery out when I store them, I use them infrequently, so far no problem.  Note that brake calipers are very different from a regular dial caliper - they need to reach in to the brake disk so you can find and measure the thinnest part.  I have digital and analog "regular" calipers, I prefer digital for precision work but carry analog around in the car because the battery won't be dead when I need it.
Offline anglesmith
« Reply #6 on: October 26, 2012, 01:30:25 AM »
I have trouble reading the ordinary vernier calipers (analog?) these days, even with glasses!  I've picked a couple of S/H mechanical dial vernier calipers ( metric and imp..) and find them very user friendly and certainly no batteries to worry about!
Graeme
« Reply #7 on: October 26, 2012, 01:46:29 AM »
Aha, showing our age, ordinary Vernier (split the lines) were great until the Dial Verniers came out.. and they are inexpensive now..
Offline Dakota Woodworker
« Reply #8 on: October 26, 2012, 12:15:07 PM »
I'll go against the flow.  I've had a digital caliper for over twenty years now, have never had problems, I use it frequently to check lumber thickness out of the sander.  In all those years I've replaced the batteries twice.  I'll have to say I've never used a dial caliper so I can't compare.
« Reply #9 on: October 26, 2012, 12:40:17 PM »
Depends on what you need it for.
 I really like the little 4" pocket dial caliper from Horror Freight. Its like, 5 bucks when you are lucky enough to catch it on sale.
 I have a laboratory grade micrometer and a "last word" jeweled dial indicator but the junker pocket dial caliper is plenty close enough most of the time
  and if I drop it there is no funeral.
Offline Mel Larsen
« Reply #10 on: October 26, 2012, 02:14:04 PM »
Rusty is right.  I have been playing with becoming a home shop machinist for about 5 years now and have found that one type of measuring tool is no where enough.  Regular micrometers are needed and the old dial calipers have their place also. A stop at your local Hock shop can produce some brand name instruments at a fraction of the original price. If you keep your eye out, you can pick up some great deals on electronic digital calipers for as little as $15.  I have a pair on ever work bench and even my desk here in the computer room.  As far as battery's go, they can be purchased on-line for as little as $3 a dozen,  most of the time they will last about 5 months.
Mel
« Reply #11 on: October 26, 2012, 04:02:25 PM »
  I am thrilled to report that I have been buying coin batteries for 99 cents a dozen, free shipping!
Ebay is loaded with them.  You have to order from central China usually, but oh well.
  That is where they come from anyway.
Offline Mel Larsen
« Reply #12 on: October 26, 2012, 04:13:07 PM »
No need to send to China for them when Amazon sells Brand named battery's for cheap. and if you happen to have their  "Prime" membership the shipping is paid.  http://www.amazon.com/b?ie=UTF8&node=389581011
« Reply #13 on: October 26, 2012, 09:40:17 PM »
Wow!! Thanks...
50 (AG13/LR44/357) for $3.40 + shipping??  Great deal as they are selling for ~$3.00 EACH here, $146.00 saving!!!
