Author Topic: Garage sale find  (Read 2895 times)
Garage sale find
« on: September 28, 2012, 11:17:39 AM »
This morning I was pleased to be a taxi for my granddaughter. Her mother dropped her off at 0700 on her way to work. My job was to get her to her Junior High by 0815. No sweat. I just took her along on some morning rat-killin' I had to do, then dropped her off at school.
Leaving her school, I drove around looking for the odd garage sale in that area. I found one, and made what I think is a good score.
A rusty old box with no name on it revealed some Duro Chrome tools!
1/2" drive speeder, #651D, Duro Chrome 1/2" drive T socket, the 10" t-bar, an 18" piece of round stock for more leverage, and a drag-link socket #1305.
In the box were also 6 hex drive sockets with the hex bar-
1-2
9-16
5-8
11-16
7-8
15-16
A vinegar bath might do these some good. The box is probaly not worth restoration, just some clean-up.
Oh , did I say I paid the princely sum of $2 ??
Re: Garage sale find
« Reply #1 on: September 28, 2012, 11:54:03 AM »
Good score for a couple bucks!
 I like the speeder and T-bar!
  With tools in this shape I can never tell how much, or how deep pits will be in advance. Sometimes they end but better than you think, and sometimes worse.
   If not electrolysis, acid.
 Vinegar works but its slow as moles asses (which also works....... slowly)
 Lately I just use watered muriatic from the hardware. When you figure you are going to cut it 2 to 1 with water, it comes out about the same price as vinegar, and works a --whole lot-- faster if the finish is mostly gone from the tools anyway.  (tip: add the acid to the standing water and never the other way around!!)
   You have do it outside, use gloves, and then scrub the tools down with baking soda/water after. ( I like 3M abrasive pads for this. It cleans and semi polishes.)
  You have to use soda with vinegar too. Acid is acid.
 Dollar stores sell plastic dishpans that fit most stuff, but that speeder will have to have something longer.
   If you leave the used acid sitting overnight you can pour off the clarified stuff on top to keep for later, and rinse the sludge down the storm drain with lots of water. No muss no fuss.
« Last Edit: September 28, 2012, 11:59:29 AM by scottg »
« Reply #2 on: September 28, 2012, 09:45:08 PM »
Noel, do you think you can get the knob working freely on that speeder? Looks pretty red from over here.
Offline dimwittedmoose51
« Reply #3 on: September 29, 2012, 03:52:08 AM »
A resto project for the rustos....good luck.  I heard that coca cola does a good job too.  Have yet to try my 5 gallon vat annode battery charger contraption.  Need some test pieces I don't care about.
DM&FS
Champion Pawn/Flea Plunderer
« Reply #4 on: September 29, 2012, 06:50:42 AM »
TriFlo will almost surely take care of the knob, or liquid wrench, or just a kerosene soak.
Offline geneg
« Reply #5 on: September 29, 2012, 07:30:54 AM »
Great $2 buy.  Good for derusting experiments.   I've used many methods for derusting.  Results always vary.
The beet sugar (molasses type process)  works well for long term treatment.  You can buy the dry mix in a 50# bag for about $10 at a feed store.  It is added to cattle feed to entice eating.  Mix a slurry like pudding- drop in your rusty stuff, stir occasionally, add water if needed.  I usually have a 5 gallon bucket with it behind the garage all Summer.  You can dump it on an unused lawn area with no ill effects, hose the stuff off, maybe scotch bright it with some water and be surprised with the results.  The toolbox may be a candidate for this a month or more is not unusual, but it is cheap and easy.
The vinegar bath can be assisted with the purchase of a garage sale crock pot.  Set the heat at the lowest, add the stuff at night, check in the morning.  Seems to work better than a cold mixture.  Whatever you do, DO NOT use the household crock pot!
I played with the electrolysis once, not sure the nasty mess & potential risks are worth the effort.
All of the above methods produce results that will flash rust immediately if not treated as soon as rinsed.  You need to coat, oil, wax, or polish to preserve the newly found treasures.
« Reply #6 on: September 29, 2012, 08:07:18 AM »
The speeder knob was free as found. I let all soak in vinegar a few hours, then neutralized the acid, scrubbed everything with a SS steel wool pad, then sprayed with KROIL. I'll go out and see what everything looks like soon.
« Reply #7 on: September 29, 2012, 02:55:09 PM »
Great find,
found mixed sets of the hex drive scockets (MM) & allen wrench drivers, just has "MADE IN USA" xx MM" with double knerling around it.
1/2" 3/8" & 1/4" drive hex, with screw driver bit, but no ratchet.. found it >45 years ago.
