Author Topic: Looks like some sort of level... pic inside  (Read 3122 times)
0 Members and 11 Guests are viewing this topic.
Offline mtds
« on: September 05, 2012, 12:29:54 PM »
Leather case marked "KR".  Brass body with threaded caps. Optics inside.  A bubble level on the outside of the main tube.  What is it?  Age?  Field of use?
Re: Looks like some sort of level... pic inside
« Reply #1 on: September 05, 2012, 12:58:26 PM »
 Thats a Kuker-Ranken sighting level. Still for sale currently.
« Reply #2 on: September 05, 2012, 06:05:26 PM »
OK, I'm game, how do you look through the sight and look at the bubble at the same time?
« Reply #3 on: September 05, 2012, 06:12:53 PM »
 Maybe consequently not concurrently ?
« Reply #4 on: September 05, 2012, 07:09:01 PM »
One eye for each..........
« Reply #5 on: September 05, 2012, 07:30:18 PM »
You'd have to be really cock-eyed to do that.
« Reply #6 on: September 05, 2012, 07:49:53 PM »
You surely would be after doing that.....LOL
It was a little bit of a serious question tho, I have seen small sighting glasses designed for a transit, usually there is something to hold it level after you set it up with the bubble to point at a horizon line...
I'm wondering how helpfull a bubble is on a pocket glass...
« Reply #7 on: September 05, 2012, 08:48:18 PM »
These are properly called a Locke level, after the gentleman that invented it.
They are hand held and are useful for quick leveling or checking level at a construction site.  Generally used where precision isn't required and you don't want to take the time to set up a builders level on a tripod.
They are a lot easier to use if you hold it against some kind of support, like a pole.
http://constructionmanuals.tpub.com/14043/css/14043_137.htm
« Reply #8 on: September 05, 2012, 09:25:07 PM »
I remember using these before the days of laser levels,they were good for quick checks on excavations and rough grades. I don,t recall the brands I worked with but they were brass and did look similar to yours
« Reply #9 on: September 06, 2012, 03:09:14 AM »
see http://www.mytoolstore.com/dwhite/hand.html $68 + $14 for the case...
used on archeological digs etc where an expensive level is not needed, to expensivem or too bulky to carry, see http://www.beg.utexas.edu/coastal/thscmp/fieldprocedures.htm
« Reply #10 on: September 06, 2012, 07:32:27 AM »
Hence the impressed KR mark on the holster.  Still made, and online:
http://www.krinc.net/17770/Kuker--Ranken-Hand-Levels.html
"The level vial is mounted atop a slot in the sighting tube in which a reflector is set at a 45° angle. This permits the observer, who is sighting through the tube, to see the object, the position of the level ..."
Offline mtds
Thanks to all for answering my question!
« Reply #11 on: September 06, 2012, 05:02:24 PM »
Thank you all for answering my question, plus the additional interesting comments!
« Reply #12 on: September 06, 2012, 05:08:55 PM »
That's what we do!
« Reply #13 on: September 06, 2012, 05:22:13 PM »
Ahhhh!
