Author Topic: A challenge for the what's-it folks...and an eventual answer  (Read 6470 times)
« on: August 30, 2012, 01:35:22 PM »
See how you make out on this set of strange looking pliers.
If nobody gets it right by Sunday morning I'll post the answer.  With the talent in this forum I have a hunch somebody will come up
with the right answer.
Just a slight hint...they were patented.
Have fun.
Re: A challenge for the what's-it folks...and an eventual answer
« Reply #1 on: August 30, 2012, 02:04:37 PM »
Cobbler's pliers?
« Reply #2 on: August 30, 2012, 03:29:06 PM »
Not for leather work, not with spreader jaws on one side and pipe jaws on the other.  The teeth are too big for lasting pliers, and no fulcrum for pulling with those jaws.
« Reply #3 on: August 30, 2012, 03:45:59 PM »
Very well...
Then how about Pazzano Battery Terminal Clip Pliers?
« Reply #4 on: August 30, 2012, 06:16:28 PM »
lbgradwell,
   You are correct.  Mine are marked Whitaker and the reissue patent no. 19027.  Original. pat. no. was 1,898,568.
I kind of figured somebody would come up with the answer...just not this quick.  I'm impressed!!
I'll have to pick something harder next time.
Link below.
http://www.datamp.org/patents/displayPatent.php?number=19027&typeCode=1
« Reply #5 on: August 30, 2012, 06:48:48 PM »
No doubt re-badged for the Whitaker Battery Supply Company (later Whitaker Cable Corporation)!
« Reply #6 on: August 31, 2012, 02:34:01 PM »
 mine are stamped pat no 19027made in usa Pazzano wrench co Waltham,Mass would have replied earlier but was too lazy to go to basement and get photo.
« Reply #7 on: August 31, 2012, 07:34:55 PM »
Great picture, is it yours
« Reply #8 on: August 31, 2012, 07:42:22 PM »
Guys,
    Obviously these are more common than I thought.  I'll have to find something a little more challenging the next time.
Thanks for the participation.
« Reply #9 on: August 31, 2012, 08:23:28 PM »
No sir; just an image swiped from the Web!
Offline strik9
« Reply #10 on: August 31, 2012, 09:28:32 PM »
Are there examples of these curved pliers with a small hammer head in place of the spreader?
   I think I know where one is local to me.
« Reply #11 on: September 01, 2012, 03:11:14 AM »
Strik9 - see above - you are thinking of cobbler's lasting pliers.... Never seen this type of battery terminal pliers in the UK...
« Reply #12 on: September 01, 2012, 03:13:00 AM »
I've seen this sort of battery pliers in the UK - but I think even these are US in origin...
« Reply #13 on: September 01, 2012, 05:22:51 AM »
I think Ill swipe it again then
« Reply #14 on: September 01, 2012, 06:47:31 AM »
These last aren't really battery pliers, they are a clamp lifter.  Made to push against the battery post, while lifting the clamp off, I've seen more batterys damaged and with leaking posts from guys getting too rough pulling the clamp off.   I could actually use a pair like this.
