Author Topic: What is it?  (Read 4482 times)
What is it?
« on: August 25, 2012, 08:59:44 PM »
found this in old tool box,
4" long, 1" wide legs (Omega shape), leather covered handle with a loop on end to legs.
what is it used for? how? why?
ooh, just noticed it has a spring steel tang on the side, maybe to hold back thick thread like a tensioner?
« Last Edit: August 26, 2012, 05:08:51 AM by oldtools »
Re: What is it?
« Reply #1 on: August 25, 2012, 10:05:57 PM »
You know the little Green Guy that sometimes shows up in photos?  This is one of his relatives.
Offline strik9
Re: What is it?
« Reply #2 on: August 25, 2012, 11:19:19 PM »
It kind of looks like something to help get your cowboy boots off.
  Slide the heel into the U part and step on the loop part, lift foot out of the boot.
 A severe case of WAGging her but I've seen something like that before.
Re: What is it?
« Reply #3 on: August 26, 2012, 03:42:06 AM »
For mini boots?, 4" X 1", fit in your hand.
but I see if it was larger it could be...
Just thought of a use for this tool.. holding the handle, with index finger agance the loop (as a stopper)
it has a good solid grip to pull over a seam or edge to round it off, like leather work?
 ~3/8"Dia. inside the legs is rounded in direction of the pull.
But just guessing...
« Last Edit: August 26, 2012, 05:01:21 AM by oldtools »
Offline anglesmith
Re: What is it?
« Reply #4 on: August 27, 2012, 03:56:40 AM »
This one is very intriging, how is the side arm attached? The top end seems to be solid with tang (handle),  but I can't see how the lower end is connected. I think it is very old, possilby early 1800s? and looks to be purpose made, not just a lashup. I  can't discern the spring, is it possible to have a couple of close up photo's.  I keep thinking kitchen /fire place /hearth!? maybe because the feet look like a minature fire dog! As I said very very intriging.
If we can't discover what it is here you should put it on the Whats it blog. http://55tools.blogspot.com.au/search?updated-min=2012-01-01T00:00:00-05:00&updated-max=2013-01-01T00:00:00-05:00&max-results=11
Graeme
Re: What is it?
« Reply #5 on: August 27, 2012, 06:40:32 AM »
Thank you, will check the blog out..
Offline Rob H.
Re: What is it?
« Reply #6 on: August 29, 2012, 05:01:01 PM »
I think that this tool is a cock fighting spur, a weapon to be tied to a battle cock's leg.  Below is a photo that I shot of some spurs, their shape is very similar.
I think we need to see the item without the leather sheath, can you post a photo without the leather cover?  This style of spur is called a long knife, the blades come in many different styles, if you do a search on cock fighting long knife you will see some examples.  The metal part on the leather sheath looks like a clip for clipping it to your pocket, belt, etc.
Offline anglesmith
Re: What is it?
« Reply #7 on: August 29, 2012, 10:15:37 PM »
Rob H. Good work I think your on to it, in fact afer googling I'm sure you are right. I was puzzled at the "leather handle" but now it seems that it's a cover!
We will just have to wait for Oldtools to remove the cover!
Graeme
« Last Edit: August 29, 2012, 10:25:31 PM by anglesmith »
Re: What is it?
« Reply #8 on: August 30, 2012, 01:13:31 AM »
That's one heck of a first post!  I can't see it being anything else now.
Re: What is it?
« Reply #9 on: August 30, 2012, 04:05:25 AM »
Amazing! You guys got it!
I never considered pulling the leather handle off.
it was stuck, rusted to the blade, but with a little jigling, it came off,
cleaned it up, it is very sharp, could kill something with it!!!
the leather sheath could be clipped to a pocket like a pen clip. or could be used for sparring practice.
Re: What is it?
« Reply #10 on: August 31, 2012, 07:07:03 AM »
Well done Rob!
Re: What is it?
« Reply #11 on: August 31, 2012, 09:26:52 AM »
Unbelievable!  Wouldn't it be fun to read the patent for that one.  Thanks Rob and welcome to Tooltalk.
