Author Topic: Thorsen tools collection  (Read 307043 times)
0 Members and 24 Guests are viewing this topic.
Offline TOOLHOUND!
Re: Thorsen tools collection
« Reply #15 on: July 30, 2012, 10:36:04 PM »
The JCPenney set I discovered is a 3/8" drive metric set.
All of the sockets begin and end with the familiar Thorsen "=".
The ratchet that came with the box on the upper left looks to be a Thorsen ratchet head design, but the ratchet is blank except for Japan stamped on the back side.
The S-K sourced JCPenney ratchet and wobble in the upper right I included for comparison.  Both ratchets have black reversing levers.
The extensions I added to the set, but also have "=" before and after their markings.
Offline stormking
« Reply #16 on: July 30, 2012, 10:50:41 PM »
You have an awesome collection, I have also admired your tool boards in another thread. I have not run across any avid Thorsen collectors so would like to get your opinion. I picked up a nice 3/4" drive Thorsen set a few weeks ago, and am puzzled by the socket marks. They have the hot forged logo stamped in the socket, the only ones I have ever seen (which is very few) have been 3/4" drive. Have you seen any other sizes? Picture to show example. Thanks
By stormking3 at 2012-07-20
« Reply #17 on: July 31, 2012, 03:23:03 AM »
Great collection of thorsen stuff you have there........Looks good :)
Offline amertrac
  • ny mountain man
« Reply #18 on: July 31, 2012, 03:27:15 AM »
Mr. Rascal , do you use these tools as every day working tools. If so you do take good care of them  nice set bob w.
« Reply #19 on: July 31, 2012, 07:56:46 AM »
I've looked through every Thorsen socket I have.  None have this "Hot Forged" marking on the tool itself.  For example, the 528 - 7/8" - 1/2" drive - 12 point - I have 32 of them - 12 unique variations - none with the marking you show.
Please let me know should you ever be interested in parting with that 3/4" drive set.  It is certainly a beauty, and one I'd love to put beside the others.
The only occasions where I've used them is when I've traveled needing tools.  I do plan to change that once I'm a little more near complete.
Thanks, Nola!
They certainly have a lot in common - not just the script.
« Reply #20 on: July 31, 2012, 09:23:50 AM »
SAE 1/2", 3/8", and 1/4" drive sockets (aligned horizontally on series, and vertically on size):
Top row is 6xx series (1/2" drive, deep, 12 point) - from left to right
632, 630, 626, 624, 620, 616
Second row is 5xx series (1/2" drive, shallow, 12 point) - from left to right
540, 538, 534, 532, 530, 528, 526, 524, 522, 521, 520, 519, 518, 516, 514, 512
Third row is 6xxJ series (3/8" drive, deep, 12 point) THEN  6xxJX series (3/8" drive, deep, 6 point)- from left to right
626J, 624J, 620J, 618J, 616J, 614JX, 612JX
Forth row is 6xxJR series (3/8" drive, deep, spark plug)  - from left to right
626JR, 620JR
Fifth row is 3xx series (3/8" drive, shallow, 12 point)  - from left to right
328, 326, 324, 322, 320, 318, 316, 314
Sixth row is 3xxX series (3/8" drive, shallow, 6 point)  - from left to right
316X, 314X, 312X
Seventh row is xxM series (1/4" drive, shallow, 12 point)  - from left to right
16M, 12M, 11M, 10M, 9M, 8M, 7M, 6M
Eight row is xxMS series (1/4" drive, shallow, 8 point)  - from left to right
12MS, 11MS, 8MS
« Last Edit: July 31, 2012, 09:27:05 AM by OilyRascal »
« Reply #21 on: July 31, 2012, 09:48:31 AM »
3/8" drive universal swivel sockets
Top row 4xxJ series - 3/8" drive - 12 point (from left to right)
428J - 7/8"
424J - 3/4"
422J - 11/16"
420J - 5/8"
418J - 9/16"
416J - 1/2"
412J - 3/8"
bottom row 4xxJX series - 3/8" drive - 6 point (from left to right)
416JX - 1/2"
414JX - 7/16"
412JX - 3/8"
« Last Edit: July 31, 2012, 11:57:57 AM by OilyRascal »
« Reply #22 on: July 31, 2012, 12:14:42 PM »
Pliers:
1) 6" Slip-joint pliers marked "Thorsen SJ-6" - with "U42" cast into the shank
2) 8" Slip-joint pliers marked "Thorsen SJ-8" - with "K09" cast into the shank
3) 8" Slip-Joint pliers marked "Thorsen Allied SJ8AL"  /  "Drop Forged Japan"
4) 6" Slip-joint pliers marked "SJ6AL TAT KOREA"
5) 10" water pump pliers marked "Thorsen Allied 6J10AL" / "Forged Steel" / "Spain"
6) 6" Needle nose pliers marked "Thorsen USA LN-6"
« Reply #23 on: July 31, 2012, 12:22:58 PM »
Adjustable wrenches (seen here before, but posted again for the sake of grouping Thorsen).  From the top:
1) 10" marked "10IN. Thorsen AW-10 Forged Alloy Steel" / "10 IN. MFD.USA T99" with MFD over USA and "t99" perpendicular to the other scripting.
2) 10" marked "10" Allied" / "China"
3) 8" marked "AW8AL Thorsen Allied" / "Forged Alloy Steel Spain"
4) 6" marked "AW6AL Thorsen Allied" / "Forged Alloy Steel Spain"
5) 8" marked "8"/200mm Thorsen 56728" / "Euro-style Wide Grip"
6) 8" marked "8"/200mm Thorsen 56728" / "Euro-style Wide Grip"
« Reply #24 on: July 31, 2012, 01:48:31 PM »
Wrench pictures with the framework on the numbering construct.  They were made in, at least, the following configurations; not yet addressing the various shank styles, scripting, and markings.
10xx series - short pattern - metric combination wrenches with an offset on the 12 point boxed end.
10xx series - long pattern - metric combination wrenches with an offset on the 12 point boxed end.  Note the two smaller 6-point boxed ends.  It seems to be a trend of Thorsen to move from 12-point to 6-point in offering on the lower sizes.
11xx series - metric double open end wrenches
not pictured
20xx series - short pattern - SAE combination wrenches with an offset on the 12 point boxed end.
20xx series - long pattern - SAE combination wrenches with an offset on the 12 point boxed end.
Center row, from the top
21xx series - short pattern - SAE double boxed end 30 degree offset 12 point wrenches
21xx series - short pattern - SAE double boxed end 15 degree offset 12 point wrenches
22xx series - long pattern - SAE double boxed end 30 degree offset 12 point wrenches
22xx series - long pattern - SAE double boxed end 15 degree offset 12 point wrenches
30xx series - SAE double open end wrenches
« Last Edit: July 31, 2012, 02:58:54 PM by OilyRascal »
« Reply #25 on: July 31, 2012, 05:16:13 PM »
Of the 95 various wrench configurations (again, not diving into variations of script, logo, marking, knurling, etc.) that I currently know have existed - 54 are represented in Thorsen USA - 41 are not.
« Reply #26 on: July 31, 2012, 06:40:42 PM »
Thorsen 42J 3/8" drive, 6-1/2" long, 4.6oz sliding t-bar with markings "Thorsen MFD. U.S.A. 42J" with MFD. over U.S.A.
« Reply #27 on: July 31, 2012, 06:46:24 PM »
Thorsen CP center punch at 5" long and 2.2oz - markings of "=CP Thorsen USA="
« Reply #28 on: July 31, 2012, 06:51:00 PM »
Thorsen SP 3/16" punch at 5-1/2" long and 3.2oz - markings of "=SP Thorsen USA 3/16="
« Reply #29 on: July 31, 2012, 06:57:08 PM »
Thorsen 774 combination open ratchet end and 12 point boxed end - markings of "Thorsen Tools - Oakland - Calif." on one shank, and "7/16 SPEED-???" + some small text over small txt + "774 0" .   I would say it reads "SPEED-WFR" - but can't be certain.  It weighs 1.7oz and is 6-1/4" long.
