Author Topic: Sirs: a little Model T info please?  (Read 8894 times)
Re: Sirs: a little Model T info please?
« Reply #15 on: July 28, 2012, 08:35:03 PM »
Both the Ford scripts or just the USA marked one?    I really prefer the plainer one with the Ford to be the older but I would like to get this as correct as possible.
Speed and deadlines really don't matter on this as much as getting the right aged tools.
  I will probably have a local make the pouch for me out of naugahide with a kevlar liner.  My Ebuying powers are very limited so local is the preferred route to aquire things.
Maybe I am un-clear but just to clarify I was referring to the Dodge wrench
« Reply #16 on: July 28, 2012, 08:38:27 PM »
If you want your Model T set to be correct, then go with the info on the website I posted. I highly doubt they would post anything without research into it.
There really weren't that many wrenches that went into that toolkit, anyway. Should be easy to find.
Offline strik9
« Reply #17 on: July 28, 2012, 08:57:34 PM »
Keykeeper, now that the weekend is here I have a chance.  Weekday life gets in the way of internet surfing a bit.
1930, thanks for the info.   The other Q wrench is SAE marked with no D.B. in the number so it is clearly later.  Although it is of the same design and form.
