Author Topic: Help Needed - Identifying Wrenches  (Read 3832 times)
Offline JessEm
  • MinneSNOWta
« on: July 05, 2012, 04:35:35 PM »
I have a few wrenches I'm trying to identify. I believe they're mostly from old tool kits or implement wrenches...
1) This one is weird. It measures 6.75". The number 28 is stamped on one side, the other side lists the sizes incorrectly as 5/16 and 7/16, when they are a much larger 5/8 and 13/16.
2) This one is smaller. It might be recognizable to someone familiar with its unique handle. Does it serve a purpose?
3) This wrench simply has the number "43845", and measures 5.5".
4) This is stamped "H-2". It's seen better days but the sizing is still legible. It measures just over 7".
5) These two wrenches have the letter "M". However, one of them could be a "W"... The larger wrench also has the number "25".
6) These three are unmarked. The longest measures 6". They're fairly sturdy for their size.
7) The last wrench is itty bitty. The spark plugs it's for must be pretty small...
« Last Edit: July 05, 2012, 04:47:52 PM by JessEm »
Offline Neals
  • Alberta, Canada
Re: Help Needed - Identifying Wrenches
« Reply #1 on: July 05, 2012, 05:09:26 PM »
I'm guessing the last picture is magneto wrenches.
« Reply #2 on: July 05, 2012, 05:25:59 PM »
The sizes on #1 would be early sizing matching the diameter of the shaft of the fastener, not the head.
Quote
In the late 19th and early 20th centuries, wrench sizes were commonly named by the nominal size of the bolts whose nuts they fit, rather than the size (across the flats) of the nuts themselves. For example, a "1/2" opening might fit a 7/8 (across the flats) nut threaded on a 1/2 inch bolt.
Go to Alloy Artifacts for more info- http://home.comcast.net/~alloy-artifacts/table_oe_wrench.html
Yes the last ones are magneto and point system tools.
Offline amertrac
  • ny mountain man
« Reply #3 on: July 05, 2012, 05:33:09 PM »
The second wrench( third pic)  i deleive is a farm equipment wrench. Years ago i saw one on a tracyor and it was haning on a pin or bolt . Of course farmers used to hang everything on the tractor    bob w.
Offline JessEm
  • MinneSNOWta
« Reply #4 on: July 05, 2012, 05:43:02 PM »
Thanks for the input.
Papaw, That link completely explains the numbering, and "weird" sizing, on some of these wrenches... Thank you!
« Reply #5 on: July 05, 2012, 08:07:02 PM »
H-2 is a Tappet wrench, they came in 4 sizes from someone, H1,H2,H3,H4.....
Offline Hm Wrench
    • Vintage tool kit Source for Motorcycle tool kit ID
« Reply #6 on: July 05, 2012, 08:58:10 PM »
The tappet wrench is herbrand.  The fifth photo with the wrench with the M is Moore drop forge, possibly from a ford tool kit.  The last wrench looks like a version of the bosch delco ignition wrench.
Thanks,
Kirk
Always Looking for Motorcycle, Bicycle tools and related information.
Offline JessEm
  • MinneSNOWta
« Reply #7 on: July 07, 2012, 11:56:06 PM »
The last wrench is indeed stamped "AB" on the back, for American Bosch Magneto Corp.
Thanks for the help. Just curious what I had.
« Reply #8 on: July 08, 2012, 10:19:57 AM »
Just as an aside, some old spark plugs had a nut on the top to hold the wire rather than the push on type wire connectors used today. The small end of a spark plug wrench would fit the nut....
