Author Topic: Tools?  (Read 3523 times)
Tools?
« on: June 14, 2012, 06:44:15 PM »
I have two candidates where I'm unclear on whether they are a tool.   Any help would be appreciated.
1)  Marked "W&B" on one shank, and "No2" on the other.
2) Marked only with 87139 - it has a rod with a hooked end that sleeves inside what appears to be the attaching end.  It is spring loaded inside the sleeve (and knotched to provide a travel limiter)
Re: Tools?
« Reply #1 on: June 14, 2012, 06:53:16 PM »
First one is for removing drill bits from morse chucks.
Not a clue on the second one...
Re: Tools?
« Reply #2 on: June 14, 2012, 07:25:08 PM »
Thanks, Rusty!  I know exactly where I need to use it now - Champion Blower & Forge drill press
I have two others I neglected in the original thread.
3) About all I have is - It may have had some chrome looking plating at one point.
The 4th is clearly a tool - but for what, by who, and at what time I can't make any headway on.  It is wood handled.  The working end (while appearing to be a nutdriver) has a ~1/4" (FAT) socket that appears to accept a very very very small spline ~30 count.
Re: Tools?
« Reply #3 on: June 14, 2012, 07:58:03 PM »
The first one is Whitman & Barnes (in case you don't know)...
Re: Tools?
« Reply #4 on: June 14, 2012, 08:04:43 PM »
I didn't!  Thank you.
Re: Tools?
« Reply #5 on: June 14, 2012, 08:44:44 PM »
I *think* #3 is a lid lifter and grate shaker for a coal cook stove......
Re: Tools?
« Reply #6 on: June 14, 2012, 09:24:31 PM »
A speedometer tool of some sort maybe?  I'm no mechanic just thinking about all those little plastic adapters I've seen in catalogs for speedometers.
the working end of the wooden tool #4
Re: Tools?
« Reply #7 on: June 14, 2012, 10:18:29 PM »
The spline wrench socket looks a lot like the spline hole on a Maytag wrench.  I do not know the function of that wrench.  Maybe one of our hit and miss engine guys can give their two cents worth.
Re: Tools?
« Reply #8 on: June 14, 2012, 11:15:41 PM »
On No.3, I agree with it being a stove tool, the 3 sided socket for turning the clinker breaker, shaker, and the other end for lifting the round lids on the stove top.  no.2, I should know,  have seen one somewhere,,,
Re: Tools?
« Reply #9 on: June 15, 2012, 05:15:00 PM »
Splines typicly occur on appliances on shafts where you are using a nut to hold a bearing, and need to hold the shaft itself while tightening the nut, easier to make a spline on the end that goes through the nut than to make 6 flats on a hardened shaft..(stronger too)
 I can't see a nut driver type tool being helpfull for that tho, usually need a lot of torque to get those kinds of things apart...
Many other things use splines tho, magnetos for example....
Some fasteners that accept screws are initially installed with a spline tool also...
Knurled electrical connectors are sometimes spline nuts in disguise...
Very hard to guess, and it *could* be a general purpose tool, tho I can't say I've ever seen a set of those...
