Author Topic: What is this thing? Kraeuter 1203-11  (Read 4584 times)
Offline FrankLee
« on: May 28, 2012, 07:25:13 AM »
I recently found this Kraeuter tool but have no clue as to what it is.
There's one on ebay and they describe it as a wood carving tool. I can't see that any edge can be sharpened enough to carve wood.
http://www.ebay.com/itm/Vintage-Kraeuter-1203-11-Wood-Handled-Wood-Carving-Tool-/370536870471?pt=LH_DefaultDomain_0&hash=item5645b7f247
Anyone have a Kraeuter catalog?
Re: What is this thing? Kraeuter 1203-11
« Reply #1 on: May 28, 2012, 07:30:09 AM »
I have a set of these.  It is a bearing scraper, for smoothing poured lead babbit bearings.  For instance, in the Ford Model A manual, after pouring new bearings for the crankshaft, install the crankshaft, rotate, noting the high spots in the babbit.  Then scrape the babbit level so there is a 95% contact amount between the babbit and journal.  Factory machines had some poured bearings too, before WWII.  The edges should be filed flat, to give a good scraping surface.
« Reply #2 on: May 28, 2012, 10:35:53 AM »
Ditto, bearing scraper.
I did not know Kraeuter made bearing scrapers, but Alloy artifacts has one on display (slightly different model, but almost identical)
Apparently Kraeuter also held a 1910 patent for it....
http://home.comcast.net/~alloy-artifacts/kraeuter-company.html#kraeuter-1202-13
« Reply #3 on: May 28, 2012, 01:44:45 PM »
Bearing scraper. I use to use them when repairing Aermotor windmills. I recently bought one made by Plomb.
Offline FrankLee
« Reply #4 on: May 28, 2012, 02:11:16 PM »
Thank you all for the info.
« Last Edit: May 29, 2012, 05:54:13 AM by FrankLee »
Offline Batz
« Reply #5 on: May 29, 2012, 03:05:32 AM »
I have a full set of those as well, in fact I'm off to work at a power station next week and I'll be scraping white metal bearings for several days. Some of mine where made by a blacksmith from old outer bearing races many years ago.
Offline sumner52000
« Reply #6 on: May 30, 2012, 02:57:06 PM »
