Author Topic: Need help with a drill.  (Read 7034 times)
Offline m_fumich
« on: April 28, 2012, 01:35:24 PM »
I'm gonna restore this drill if I can. Any idea how the chuck comes off? It's a Jasco Junior.
Offline JessEm
  • MinneSNOWta
Re: Need help with a drill.
« Reply #1 on: April 28, 2012, 01:53:35 PM »
Milwaukee Porta-Band?
Seriously though, I have no idea. Wish I could be more help. Good luck with it.
« Reply #2 on: April 28, 2012, 02:33:35 PM »
There is usually a screw inside the jaw (which means you have to get the jaw to open first. Good luck -P
*beware* - sometimes the screw has left hand threads.
« Reply #3 on: April 29, 2012, 09:04:40 AM »
Quote
And often quite tight due to the rotation and years of not being removed!
Offline dimwittedmoose51
« Reply #4 on: April 29, 2012, 09:56:40 AM »
I'd say the first step is a week's worth of an ATF/Acetone bath and the nsee if the chuck will spit  that bit out.  Let us know how that goes.....
DM&FS
Champion Pawn/Flea Plunderer
« Reply #5 on: April 29, 2012, 10:41:23 AM »
If the drill has reverse, it will definitely have a screw inside the chuck and it will definitely be left handed.
 It probably doesn't reverse though, from the age of it.
 But you still have to open the chuck to check!!
If it has one, it has to come out first!!
  After the week long (2 is better) soak in penetrant, put a 3/8" hex key in the jaws (the short side) and cinch the jaws down tight.
 Now take a light hammer and knock the chuck loose by striking the long leg of the allen key in a counterclockwise manner.
 You want lightweight hammer (8-10oz) and a very fast, hard blow.
 or 50 blows.
 But it will eventually relent, and its the only way without damaging a whole lot of stuff.
 Bigger hammer is no good. Impact wrench, definitely no good!
 fast hard impact from a light hammer will work, eventually
« Last Edit: April 29, 2012, 11:07:58 AM by scottg »
Offline Fins/413
« Reply #6 on: April 29, 2012, 04:19:50 PM »
Good luck Matt that is a good looking drill.
1959 Chrysler New Yorker
1982 E150 Ford van
Offline m_fumich
« Reply #7 on: April 29, 2012, 05:51:19 PM »
It does not have reverse. The motor still works but I don't use it. I put that bit in several years ago. I let it sit under the car port until s couple yours ago. The last time I used it was the first time I used it. It made my hand all tingly.
It will get at least 2 weeks on JAFE Juice. I'm out 2 weeks at a time, at least. Once I set it up to soak, no one will touch it until I get home. I just need to find some place to put it. No garage or car port at this house.
« Last Edit: April 29, 2012, 07:41:33 PM by m_fumich »
« Reply #8 on: April 29, 2012, 06:06:13 PM »
Quote
cat port
Matt, most cats don't need a special place to lay around!
Offline m_fumich
« Reply #9 on: April 29, 2012, 07:43:38 PM »
THAT'S what you pick up on. No comment about the drill making me feel like I had a couple bumble bees in my hand? Sure, go straight for the funny stuff. :)
« Reply #10 on: April 29, 2012, 07:45:15 PM »
The tingling was in anticipation of my jibe at you about a "Cat Port"!
« Reply #11 on: April 29, 2012, 11:17:29 PM »
[Matt, most cats don't need a special place to lay around!
Sure they do!  On top of anything, especially anything you just laid down.  It's all special to cats.
