Author Topic: Early Indestro Socket?  (Read 4300 times)
« on: March 11, 2012, 10:13:20 PM »
I have a socket (and square drive? x slotted screwdriver? attachment that was inside it) that I believe is an early Indestro socket.
Indestro No. 220 1/2-Hex Drive Socket Set documented on AA seems correct.  However, the socket I have is considered a "square drive", correct?
Offline KeepinOldBolts
Re: Early Indestro Socket?
« Reply #1 on: March 11, 2012, 10:41:15 PM »
Hard to tell from the pic. Those sockets can be hex drive or square drive. Same with the sized end. They can be 4pt or 6pt.
« Reply #2 on: March 11, 2012, 10:48:44 PM »
Quote
So, it is square.
« Reply #3 on: March 11, 2012, 10:49:00 PM »
Let's try a shot of the drive end :)
« Reply #4 on: March 11, 2012, 11:14:46 PM »
If the bottom has a hex broach, its a hex drive, square socket. For square nutz 'n bolts and a hex drive ratchet or speeder or somesuch.
  If the bottom is square too, its just a square socket :)
« Reply #5 on: March 11, 2012, 11:26:45 PM »
That was the drive end, the other end having a 15/16 hex (broach as you call it).  So I do have a 1/2 square drive socket just as I thought.
And this is a hex drive??? flipped over in the socket set pictured (completely unrelated socket to OP)?
« Reply #6 on: March 12, 2012, 12:00:33 AM »
I'm sure that screwdriver bit didn't belong in that socket, it goes in the ratchet as a screwdriver.
« Reply #7 on: March 12, 2012, 12:26:30 AM »
Thank you all for the help.  I had to make sure I was correct in this being a square drive, as all sockets I'm finding in that style are documented as hex drive.  I don't like assuming.
I'm learning  -  I won't have to ask that question again!
« Reply #8 on: March 12, 2012, 01:04:51 AM »
I take my statement back, the ratchet is female hex drive, so I guess the screwdriver does go in that socket.
Offline amertrac
  • ny mountain man
« Reply #9 on: March 12, 2012, 06:57:54 AM »
shucks I always thought the screwdriver was also the short ext for the female ratchet
bob w.
« Reply #10 on: March 12, 2012, 06:29:26 PM »
The screwdriver goes with a female ratchet in a set that that socket probably also went with. The square drive sockets in this design are noted by AA, there just isn't a set shown.
This combination is a transition design, and not common...
Bob is also  right, because the screwdriver has 2 detent balls, it also serves as a ratchet-socket coupler.
Offline eddie hudson
  • NYC
« Reply #11 on: March 12, 2012, 07:55:06 PM »
bob w.
You are correct
Yes you do.
Yes it is.
