Author Topic: Not so newbe WV  (Read 3346 times)
Offline SteveD
Not so newbe WV
« on: January 22, 2012, 08:17:46 AM »
Hey Gents,
 I was on here when Noel first started this board (cant remember my username)
 My friend next door brought over this steam tool, and asked me to sell it for him.
So I thought that "Papawswrench" would be a place to ask questions about this tool and what it is worth.
Any guys on here into steam engines that can give me some history on this fancy tool?
Crosby Steam Gage and Valve company produced this steam indicator
It has a "Department Of Commerce Maritime Administration" sticker with a number on the front (see pic) next to the lock
Thanks Steve
« Last Edit: January 22, 2012, 08:23:53 AM by SteveD »
Re: Not so newbe WV
« Reply #1 on: January 22, 2012, 09:33:50 AM »
It looks like Crosby's early model, patented in the 1880's with some later improved models that you can't tell apart without inventoring the contents (an electric device was added at some point)
The Maritime administration department of the Dept Commerce wasn't formed until 1935 however, and probably wasn't doing anything usefull until 1939 or so......
The thing is for making steam indicator cards. The string goes to the steam engine crankshaft and moves the drum, creating the X axis on a graph card placed on the drum. The piston/spring thing has the pen, and measures the steam pressure in the cylinder making the Y axis on the card. The result is a graph with a trapizoid like drawing on it that tells you everything you could possibly want to know about your steam engine, like efficiency, generated power, valve leakage, headspace.....
The maritime administration was primarily responsible for the Merchant Marine, and equipment on the ships would have been privately owned, so I suspect it is from the standards department, for approving and certifying engines for new ship designs...(only a guess)
« Last Edit: January 22, 2012, 09:39:30 AM by rusty »
Offline SteveD
Re: Not so newbe WV
« Reply #2 on: January 29, 2012, 06:16:11 AM »
Thanks Rusty,  I will relay to my friend.
 Steve
