Author Topic: What are these used for?  (Read 4550 times)
Offline lebaron
« on: January 04, 2012, 08:49:33 PM »
These are marked Berry. I could not find any info on these. What are they used for.
Re: What are these used for?
« Reply #1 on: January 05, 2012, 07:59:27 AM »
They  look like fielding stamps to me.
« Reply #2 on: January 05, 2012, 08:37:39 AM »
For the "checking" on gun stocks?
« Reply #3 on: January 05, 2012, 11:26:20 AM »
They look too old for stamped "checkering."  Stamps like these, however, were used for back grounds in bas relief wood carving.  You'd carve the image, field the surrounding area down, and then stamp that area.
Offline lebaron
« Reply #4 on: January 05, 2012, 12:17:13 PM »
I think I found ones similar in leather working tools. Ebay #220767345481
« Reply #5 on: January 07, 2012, 08:49:42 PM »
They also look like the faces on bush hammers used for smoothing stone.  They could be chisel type versions of that stone mason's tool.
« Reply #6 on: January 07, 2012, 10:25:59 PM »
The bigger ones look like the feet, placed in the end of the extension tube on a Port-a-Power hydraulic press.  To keep the feet from kicking out under pressure.
Offline anglesmith
« Reply #7 on: January 08, 2012, 12:09:34 AM »
I have also seen early car jacks that had removable pads similar to the larger two?
Graeme
Offline 64longstep/Brian
  • Phoenix Arizona
« Reply #8 on: January 08, 2012, 02:29:40 AM »
Would you be willing to trade for the smallest one??
« Reply #9 on: January 08, 2012, 09:07:03 AM »
What would you forgeweld it onto, Brian?
  • Phoenix Arizona
« Reply #10 on: January 08, 2012, 03:20:28 PM »
I think it could make a good texturing stamp for leather work…
Offline Carl
« Reply #11 on: January 14, 2012, 09:56:21 PM »
 They look like shrinking dies for sheet metal work.
