Author Topic: Any thoughts for what it's for ?  (Read 1345 times)
Offline gary s
« on: June 11, 2022, 11:11:53 AM »
I have no thoughts on the wrench other than it's a multi tool.
No markings on tool. The square holes more like for square headed set screws to lock in place .
« Last Edit: June 11, 2022, 01:03:24 PM by gary s »
Re: Any thoughts for what it's for ?
« Reply #1 on: June 11, 2022, 02:28:26 PM »
Maybe garage spring adjuster?
Check google
« Reply #2 on: June 11, 2022, 03:11:49 PM »
I've seen similar bicycle tools.
« Last Edit: June 13, 2022, 09:21:24 AM by Yadda »
Offline Auggie07
  • I am interested in tools and books Middletown, CT
    • Tool Makers of Middletown Connecticut
« Reply #3 on: June 11, 2022, 03:39:40 PM »
It is a spanner wrench with different wrench sizes. I've seen some similar for use on oil drain nuts.
Dick Dickerson
« Reply #4 on: June 11, 2022, 04:15:58 PM »
Maybe a welder's tank wrench? Spanner for the gas bottle caps?
Offline gary s
« Reply #5 on: June 11, 2022, 04:19:12 PM »
Maybe it's a old automotive hub tool I've seen some that kinda look like it.
« Reply #6 on: June 12, 2022, 09:13:10 AM »
Any number of possibilities.  I've seen similar wrenches that are, I believe, intended for commercial door closers.
Offline Model 12
« Reply #7 on: June 13, 2022, 02:31:16 AM »
It's a Hook Spanner or  Pin Spanner. The way the hook/pin seems rotated inward, maybe  it's a Collet Chuck Spanner. The regular Pin Spanner likes to slip from the hole in the chuck. If it's like the picture indicates, it'll hold the curve better
« Last Edit: June 13, 2022, 02:46:11 AM by Model 12 »
« Reply #8 on: June 13, 2022, 11:01:59 AM »
This is a "door closer adjustment wrench".  Fairly common item.  Google it or type it in ebay.
« Reply #9 on: June 13, 2022, 01:56:47 PM »
This one is for a Norton or Yale closer, similar wrenches by Corbin/Russwin.
